Gasoline Leak - Odd
Old Oct 30, 2009 | 08:39 PM
Blayq Owns You's Avatar
Question Gasoline Leak - Odd
Gasoline is leaking from where my downpipe and testpipe meet. It's just a drip, but it's enough to worry me.
It must be something with the fuel lines, but I have no idea where.
The car starts and idles fine. Any help is appreciated.
Btw, I just switched to E85 from 93. Maybe that has something to do with this?
Old Oct 30, 2009 | 08:48 PM
Master Evo8's Avatar
Check the left side of the fuel rail, there is a small hose that looks like a vacuum line. See if its leaking.
Old Oct 30, 2009 | 09:09 PM
But if it was leaking from there, would it somehow find a way to drip all the way to where the downpipe and testpipe meet?
Old Oct 30, 2009 | 09:11 PM
buchnerj's Avatar
It has to be the fuel rail or the injectors somewhere, you just have to peek around back there and look for leaks at idle. Most likely is that fuel rail connection, get under the car and see what is directly above the downpipe/test pipe connection. Chances are it is just running down the back of the engine and creeping its way down to that junction...
Old Oct 30, 2009 | 09:13 PM
But it's safe to let the car start and idle with gasoline dripping all around there?
I don't want/need to die
Old Oct 30, 2009 | 09:42 PM
chaotichoax's Avatar
idling should be fine
what type of injectors...there have been quite a few threads about injectors not holding up to e85
Old Oct 30, 2009 | 09:48 PM
PTE 1000CC
When I opened the packaging they were in, one of them was capped rather than having the correct opening at the top...it looks like it was just never cut open to allow fuel to be, well, injected.
So we cut the cap open in order to allow it to release fuel. I'm wondering if that had anything to do with it. We made sure it was the correct size and cut properly, but it wasn't done with "precision" (lol) so it could be the issue.
It would be odd if that was the issue because it just today started leaking and I was tuned almost a week ago.
Old Oct 31, 2009 | 09:42 AM
Bumping this...help please!
Old Oct 31, 2009 | 11:26 AM
sho669's Avatar
I'm guessing you didn't find a leak at the rail or injectors? it has to be coming from that area and running down the block as other members mentioned.
Old Oct 31, 2009 | 11:54 AM
jjm4life's Avatar
how about the o-ring around the injector. i had a leak there. gas was all over the place.
are you having a very strong unburnt gasoline smell?
