FP HP WGA questions....
Old Nov 5, 2009 | 06:26 PM
Evoryder's Avatar
Originally Posted by sparky
You shouldn't have to bend sh*t. Send the pic to Robert at FP and get his opinion. What WGA did you order anyway? Perhaps you got an VIII actuator by mistake.
This is incorrect. No attempt should be made to rotate the actuator rod axially.
Only the turnbuckle on the end of the actuator rod rotates. The actuator rod itself does not rotate.
You're wrong. That's all.
Will you post up a pic of the slot on the actuator rod to which you refer. Glad that you solved it!
Yeah. That is not called a slot. It is the turnbuckle. It is internally threaded and rotates on the end of the externally threaded actuator rod.
This guy is wired on redbull and coffee or something
Old Nov 5, 2009 | 06:28 PM
sparky's Avatar
Originally Posted by MR Turco
So the actuator rod rotates? Just like i said it did? Weird.
Nein, Turco. The rod itself does not rotate. The actuator rod has external threads cut on the end of it. A turnbuckle with internally cut threads rotates on the end of the actuator rod. But, the rod itself does not rotate.
Old Nov 5, 2009 | 06:30 PM
jeri534's Avatar
Uhm dude, the slot is there to put a wrench on and adjust the rod if needed, I just fixed it as per the instructions of turning the rod...
Old Nov 5, 2009 | 06:33 PM
jeri534's Avatar
for further clarification for sparky
Old Nov 5, 2009 | 06:34 PM
MR Turco's Avatar
Glad you got it fixed.
Old Nov 5, 2009 | 07:25 PM
BluEVOIX's Avatar
Never had experience with the evo wga. But on the srt-4 you could turn the wga arm slightly to fit it. I'm not saying rotate it completely around, but sometimes it needs to be adjusted slightly.
From the picture it looks like extending the turnbuckle is not going to change the angle.
So did you fix it by slightly rotating the arm in respect to the actuator?
Old Nov 5, 2009 | 07:34 PM
jeri534's Avatar
yes I turned the wastegate arm just a tad and it lined up perfectly
Old Nov 6, 2009 | 10:18 AM
sk8terdude929's Avatar
I had to do the same with my FPGreen, not rotate it but just angle it differently. Also had to use pliers to pull the arm onto the turbo. I was told thats normal (preload)
Old Nov 6, 2009 | 07:02 PM
sparky's Avatar
Caution should be exercised to not turn, twist, or force the threaded actuator rod emerging from the wastegate cannister. Inside the cannister the actuator rod is affixed to a delicate diaphragm. Hold the rod stationary while slackening the locknut and screwing the extension piece(turnbuckle) on or off the actuator rod as required. Axial movement of the actuator rod however, is perfectly O.K., as this is what it was designed for.
