missing at idle and wants to die when heater or ac is turned on
Old Nov 30, 2009 | 03:44 PM
EvoBrian's Avatar
My buddies 04 is acting up and has been for awhile. It was backfiring and idling funny for awhile almost like a miss or as if the timing is being advanced then retarded. Finally it threw a code for the crankposition sensor then two weeks later died all together. Replaced the sensor starts now but does the same weired idle. If you go to turn the heater on or the ac it drops idle and wants to die. Stock turbo, full three inch exhaust and an air intake. Any ideas?
Even tried resetting ECM
Old Nov 30, 2009 | 03:54 PM
bluebanana23's Avatar
what rpm does the idle drop down to with the a/c on at idle?
Old Nov 30, 2009 | 05:17 PM
EvoBrian's Avatar
like 400-500 sometimes lower
Old Nov 30, 2009 | 05:30 PM
evo8nfs's Avatar
check you alternator??
Old Nov 30, 2009 | 06:21 PM
lelek's Avatar
i had the same problem in my nissan and it was idle control valve
Old Nov 30, 2009 | 06:33 PM
mitsuevo803's Avatar
+1, that happened in my 03 evo
Old Dec 1, 2009 | 09:13 AM
EvoBrian's Avatar
And if it was the idle control motor it wouldnt throw a code would it?
Old Dec 2, 2009 | 01:52 PM
mine never threw a code. i got my IAC from abby @ milspec if i remember correctly for $50
Old Dec 4, 2009 | 05:43 PM
EvoBrian's Avatar
Is there a like to there website available?
Old Dec 4, 2009 | 05:48 PM
buchnerj's Avatar
PM him on here. I am sure he will give you all the info you need.
cplillges
May 25, 2017 04:33 AM
cali11b
Lancer Troubleshooting
Apr 27, 2011 07:35 AM
killerpenguin21
Mar 24, 2011 06:35 PM
skforty
Oct 15, 2010 04:37 PM
okevolutionVIII
Aug 9, 2009 06:36 PM
