Where to buy internal transfercase parts?
Since the dealership doesn't carry any internal parts for the transfercase has anyone had any luck sourcing parts for it. I'm mainly intererested in the seals and o-rings around the acd clutchpack. Obviously these parts exist as sheptrans and others say they replace them when rebuilding your transfercase.
Thanks in advance
Thanks in advance
I'm hoping you guys saying tge dealer carries the is right! Now just need a diagram or part number so the idiots at the parts counter can order them for me!
this should help. seal info at bottom of page with part numbers
http://www.roadraceengineering.com/e...e-moreinfo.htm
Bump for anyone coming up with a parts diagram or some more parts number!
Just an update:
I went to the dealership and was able to get the o-rings to seal the case and the one of the internal seals for the dif. So I still need the orings for the acd pressure plate and the large seal seperating the acd and the ring and pinion.
Anymore ideas? Or does someone haves busted acd tc that I could get some parts off!
I need the large seal on the inside of the acd "pressure plate" I'm pointing to where the seal goes and beside is what's left of the seal that was there
pulling the "pressure plate" exposes the location of the two large o-rings that I need. First picture has me pointing to the "pressure plate" and the second pic shows where the inside and outside oring sit.
hope that helps
hope that helps
yeah that helps. problem is those seals likely go bad when the clutch pack over heats. so I dont think I will have those seals without getting them form a good clutch pack. I will check on monday. I have a t-case to build and I will see what I have for seals.
Thanks man that would really help out!
A local bearing and seals shop tried to match them up by taking a few measurements but I would hate to put it all back together and still have issues I rather get seals that I KNOW will work.
Are you a shop?
Are you a shop?
