I may have an Exhaust Leak
Old Oct 26, 2003 | 03:31 AM
Hooptie157's Avatar
I just installed a ultimate racing high flow 3 inch cat mated to my B&B turbo-back and I think I may have a leak. At full throttle I hear a kinda whirring noise from something (not turbo). It kinda sounds like the turbo but not as high pitched (If this makes any sense please help). Could the cat have cleared up the exhaust so much I can hear my RMR intake more or is it the exhaust ifself making that noise?
Also my car putting out some weird smell. I thought it could be the cat breaking in (which it could) but I just wanted to make sure.
My idle is fine w/o any noises and my car seems to pull alot harder to redline with the new cat. Can someone tell me how to properly diagnos an exhaust leak? Thanks
Hooptie
Old Oct 27, 2003 | 06:21 AM
Jev3gs's Avatar
What gasket are you using for your downpipe?
Old Oct 27, 2003 | 06:42 AM
Hooptie157's Avatar
I'm using the gasket provided by B&B. BTW it isn't the crappy copper ones.
Old Oct 27, 2003 | 07:51 AM
SuperchargedGTZ's Avatar
i had an exhaust leak at my test pipe. I have the UR system as well and the stock gaskets. I just took some gasket maker and filled the leak for now. Were could I get some better gaskets that the stockers.....??
Old Oct 27, 2003 | 01:17 PM
Jev3gs's Avatar
Hooptie - I just got my B&B turboback with a UR test pipe also.
I did the install this week and I did not get a gasket for the downpipe. So I called B&B and they said that the downpipe doesn't come with a gasket, but to just use the stock one. I am wondering what you are using for a gasket then?
Old Oct 27, 2003 | 01:27 PM
Hooptie157's Avatar
Whoops, I though you meant gasket for DP to the cat. For that I used the ones provide for the mid pipe (for the B&B). For the DP to the turbo I used the stock one.
alex the great
Mar 23, 2013 09:48 PM
bboy_RES
Sep 16, 2007 02:13 AM
Hooptie157
30
Feb 7, 2005 06:30 AM
twinkiemobile
Lancer Troubleshooting
Feb 26, 2004 09:22 AM
