Stock ECU readiness / Go codes?
Old Dec 29, 2009 | 08:33 AM
bonebreak's Avatar
So we recently cleared a CEL and I need to get emissions. Does anyone know how long the car needs to be driven before I can get emissions? Is this documented anywhere or do people generally just guess and say 50-100 miles?
Thanks
Old Dec 29, 2009 | 08:38 AM
TeStUdO's Avatar
If the CEL is gone, you can go right away. What was the CEL for? Did you pull the code?
Old Dec 29, 2009 | 08:44 AM
punker462606's Avatar
As long as the code was cleared and doesn't come back your good to go. I have deleted codes on my friends truck and she went and got tested right away and see passed.
Old Dec 29, 2009 | 08:45 AM
bonebreak's Avatar
Well we had a few actually. The first was the ABS cause I had a blow out. Then the O2 had come on because of the test pipe that was on. Then a random TPS came up. But at this time there aren't any codes and we are putting a high flow ams cat on today.
Its an 03 Evo 8. Are you telling me I could clear the code while at the emissions shop and it will pass? I have heard mixed things on this so I was just wondering if its documented anywhere?
Old Dec 29, 2009 | 08:48 AM
TeStUdO's Avatar
Yes. As long as the CEL isnt on when they are testing, you will pass.
Old Dec 29, 2009 | 08:50 AM
All they do is plug into the obd2 port and read for any codes, if there are no code you pass.
Old Dec 29, 2009 | 08:53 AM
bonebreak's Avatar
yeah they plug in and I believe they sniff the pipes as well here in Albuquerque. But are you sure there is no readiness state? i know a Jetta I had needed to be driven 100 miles or so before it would allow emissions to be read after the CEL was cleared.
Old Dec 29, 2009 | 03:25 PM
cssaddictm4's Avatar
There is definitely a minimum amount of miles you have to clock in order for the ECU to be "ready". I ways always told it was 200mi. If you go right after you reset the code the DMV OBDII scanner will not validate your car.
Old Dec 29, 2009 | 03:47 PM
FJF's Avatar
FJF
Same with the Evo. It needs to be driven before the readiness monitors turn on.
Old Dec 29, 2009 | 04:40 PM
20gmr's Avatar
Maybe in Georgia but in Pa you have to have all the emmisions monitors completed.
There are 8 emmisions monitors visible with a scan tool, 7 out of the 8 have to be completed to pass emmisions, unless the vehicle is a 2000 -96 then it can be passed with only 6 out of 8 complete.
Its not as simple as : no light?....... here's your sticker.
Old Dec 29, 2009 | 04:46 PM
buchnerj's Avatar
It is that way in Pittsburgh. I have a test pipe, and just used to clear the code before I took it in, like in the parking lot. Worked for 2 years. Then I just had the ROM remapped to remove the O2 code.
s2kvee
Jun 17, 2016 06:20 AM
Rat Fink
May 10, 2012 01:43 PM
impact blue
Mar 1, 2012 07:12 PM
jym89709
Oct 25, 2011 12:09 AM
Beluga
Jul 12, 2010 08:27 AM
