BBK full injector sizing choices choices!
Old Jan 2, 2010 | 12:45 AM
Davethewave's Avatar
ive been looking around the different BBK dyno threads, looking specifically at the injector sizes people are using. im doing a completely new build up as this is my second evo. will 650cc injectors be enough?
MAP 400hp fuel kit (650cc injectors)
MAP 600hp fuel kit(950cc injectors)
Old Jan 2, 2010 | 01:29 AM
crichon's Avatar
What's your goal in HP ?
Do you plan to use E85 ?
Old Jan 2, 2010 | 02:05 AM
i was hoping for something close to 400hp on a mustang dyno. i know thats not really going to happen without the use of high octane fuel.
there are no e85 stations here in washington state that i know of, at least according to google maps anyways.
this car will be running 92 (yep, i said 92) octane pump gas.
Old Jan 2, 2010 | 02:22 AM
NitrousOxide's Avatar
Chad usually recommends 780s!! Its the optimum..
Porting the ex/in manifolds might get u to 400s.. Head and throttle body as well!
Old Jan 2, 2010 | 02:26 AM
tscompusa2's Avatar
you dont need an AFPR on our cars, the stock does just fine.
Old Jan 2, 2010 | 02:55 AM
well that reall knocks the price down doesnt it? very nice. i think since i dont need a fuel regulator i will buy precision injectors. thanks guys
Old Jan 2, 2010 | 04:21 AM
dieselmd's Avatar
Bingen Pacific Pride 117 E Steuben
Longview US Ethanol 416 Oregon Way
Richland Pacific Pride 1980 Terminal Drive
Seaview One Stop 4105 Pacific Hwy
Spokane Grocery Boys 3430 N Crestline
Sunnyside Conoco 1829 First St
Check out e85vehicles.com. These are the stations listed for WA state.
Old Jan 2, 2010 | 08:36 AM
awd2gen's Avatar
Go with Precision 880cc. They will still idle perfect and you wont worry about running out of fuel. If you want E85 go with 1200cc.
Old Jan 2, 2010 | 08:38 AM
buchnerj's Avatar
I second.
Old Jan 2, 2010 | 08:49 AM
DJ Brett B's Avatar
I run 880 on my ported BBK full, 91 octane+meth (28psi), with about every bolt-on/ported stock part
385whp/373wtq on Cobb's super low reading dyno @ 4200 ft. elevation in Salt Lake ( you lose about 3% of hp for every 1000 feet above sea level)
Old Jan 2, 2010 | 09:09 AM
scheides's Avatar
EvoM Moderator
Seems like most cars that are done at CBRD come with 780's, but honestly going larger doesn't hurt. I have FIC 1050's and on pump, IDC's are in the 60% area, fantastic injectors and I can also run the car on E85 with a little headroom.
If you can spend a little extra, the Injector Dynamics 1000's are amazing.
You'll need to have a pretty extensive mod list to hit 400whp on 92, but if you toss on an alky injection kit or E85, you'll break it with ease. Good luck!
Old Jan 2, 2010 | 12:15 PM
red03evo's Avatar
I would go as large as you can just "incase" you change mind and go bigger. It's not like 1000cc or 1200cc can't be tuned on the stock ecu. Good luck with the build. I would say 880cc or 1000cc just incase you change your mind in the future.
Old Jan 2, 2010 | 03:03 PM
jjm4life's Avatar
i had 1000cc in mine and it idled perfect. its all in the tune. in fact my bbk powered evo with rc1000cc injectors idled and got better mileage than my previous tune on a stock turbo and 660 injectors (i switched tuners)
Old Jan 2, 2010 | 03:10 PM
RALLInspired's Avatar
the bigger the better in the long run. as long as the injectors are scaled properly by the tuner you shouldn't have driveablity propblems with 1200CC or below also depending on the brand of course.
Old Jan 2, 2010 | 03:25 PM
Bmf's Avatar
Bmf
Go big. 1000 will leave you room to grow. I had rc 750 on stock turbo at 98% idc and when i switched to Tomie turbo there way to small 108% idc and still havnt put my cams in yet and im not done playing with the boost levels yet. Theres also a 76 station in auburn by drift office that has 101 at the pump.
