hesitation and bucking issues low rpm
Im having some issues with my evo. At around 1800-2200 rpms my afrs will shoot to the 9.x-10.x area and the car bucks like crazy. My car is also throwing a cel which i feel could be a part of this issue. I was logging with evoscan and tried to see what the cel was and i believe it said something about a fuel pump relay. I did a quick search but only found info about evo Xs having this problem. I do have a 255 fuel pump and fic 850 injectors. Could this problem be related to my tune, or is it a fuel pump problem??
my scaling is 770 off the top of my head but i forget my latencies ill have to check. I just logged my o2 sensor and it hit 0.0 a couple times. I think it may be on its way out or already dying because it just started happening with no change in my tune from when it didn't happen to when it started.
a major boost leak could cause the P0172. Got this once from huge leak at the j pipe on the old 20g set up.
The other two codes are front O2 codes could be time for an O2 replacement. This could def be a fueling issue though. However you tune is not just going to go bad if you were tuned previously and this just started happening I'd look elsewhere
thanks for the tips. The p0138 is the rear o2 i believe which makes sense because i just had a test pipe made and i think the j bung is welded at a funny angle and close to the heat shield underneath the car which could be throwing that.
The bucking happens any time. Cold start or warm start. It is very bad when going uphill in particular. I think it happens because its causing my load values to go up. When you look at a log of this stuttering happen the load shoots to 130-160 and afrs into the 9s. The hill may be putting that extra load into affect causing the stuttering condition. I looked at the fuel table at this load and rpm and the number in the cell of the table doesn't really correlate to the value thats being logged through the wideband.
A front o2 sensor may need to be replaced as well as more dialed in scaling and latencies. I just want to see if anyone has any other ideas.
