Trying to install oil pressure gauge.
Hello,
I'm trying to install a oil pressure gauge , but the oil pressure sending unit is located
above the transfer case , from the look of it , is gonna be a PITA to get access to
it, not only that it needs a special tool to remove the sender.
Is their a way to install the aftermarket sender unit without touching the oem oil sender
unit?.
thanks.
unit?.
thanks.
lol... either does the trick. That is where the stock sender is though i believe, but a lot of the units call for you to tap the hex head place or there is another spot on the right side of the engine just below the intake cam
You may want to look into this for the oil filter housing. I tried local places, and the threads just wouldn't work. Even though they said 1/8npt it still wouldn't thread in. This worked perfectly for me.
http://store.42draftdesigns.com/Lanc...ptor_p_53.html
although right now i'm having trouble removing the damn hex screw , I'm heading over
to fleetfarm to get a pipe to use as a breaker bar.
