Sad discovery!!
Old May 5, 2010 | 07:15 PM
  #31
evo8nfs's Avatar
looks like it could have cracked from overtorqing the bolt its a possibilty...
Old May 6, 2010 | 03:04 AM
  #32
MR. EVO MR's Avatar
Originally Posted by vikevo9
It's already removed and in the process of replacing all damaged parts, and this time a twin disc clutch.... and pistons, rod, cams, valves(1mm over), port 'n polish, bigger turbo, bov, wg.....
so you were like **** it, eventually its gonna happen and why not NOW!!
Old May 6, 2010 | 04:03 AM
  #33
MarylandEvo's Avatar
I wonder how frequently cracking bell housings actually is? I haven't even checked mine...I have an ACT street disc clutch and a ACT lightweight flywheel...hmm
Old May 6, 2010 | 04:26 AM
  #34
hotrod2448's Avatar
I don't think that is from your clutch unless, it's in other areas around the bell housing as well. If something in your clutch let go bad enough to do that you would be able to tell there was something wrong with it.
That looks more like a stress crack from that mount being over loaded.
Old May 6, 2010 | 06:58 AM
  #35
vikevo9's Avatar
Originally Posted by goldtooth
stress fracture?
No, the pins were trapped between the clutch and the bellhousing... At 7500 rpm it's more than stress
Old May 6, 2010 | 07:29 AM
  #36
vikevo9's Avatar
The only thing missing were the pins of the flywheel, the clutch cover (pressure plate) have marks like something was hitting the cover as well as the bellhousing.
Old May 6, 2010 | 08:27 AM
  #37
APM Racing's Avatar
Good thing you caught your problem. I use to see that happen a lot in offroad vehicles. You would not want this to happen.
http://www.youtube.com/watch?v=40dgu0hnZls
Old May 6, 2010 | 08:42 AM
  #38
ETS Michael's Avatar
My vote for changing it That sucks man, who did the clutch install? Over torque on the bolts? dropped transmission? that's horrible man. Good Luck!
Old May 6, 2010 | 10:29 AM
  #39
vikevo9's Avatar
I did the clutch, did not drop the transmission, and did not overtorque the bolts. A friend works for Mitsu as a tec. and helped me.
Old May 6, 2010 | 04:28 PM
  #40
GTijoejoe's Avatar
You will have to change it or get it welded (that should be tricky ).... the bellhousing is a structural part keeping your engine in the car....it most likely also increasing stress on your layshaft out of the mission..I would not keep driving the vehicle unless you don't care if something else larger/more expensive breaks.
Most likely that is not a type of stress/fatigue fracture..... that outwards bump suggests something trying to come out of the bellhousing.... perhaps a rivit or something off the pressure plate, who knows.... just my speculation.
Randal
Dec 11, 2015 09:01 AM
mattourcl
Mar 27, 2014 03:22 AM
Ekoy
Apr 16, 2010 06:52 AM
mhchan218
Aug 4, 2009 06:02 PM
