Water temps (stock sized rad vs mini)
Old Feb 12, 2010 | 03:29 AM
rh9's Avatar
rh9
Question Water temps (stock sized rad vs mini)
Currently, it's 21c over here, it usually gets really hot later in the year
I just put a hole into my stock radiator as the whole turbo setup was too close to the rad, I launched the car hard and the wastegate's screamer pipe hit the radiator,
I changed to a mini radiator yesterday with the same SPAL 12" puller fan I had, previously my water temps were 75-80c on the stock radiator with 2 fans, changing to the mini radiator with one spal puller fan my water temps were up to 92c
I got the arp splitter that goes all the way under the car and a greddy air diverter thing on top, trying to keep the air towards the IC and rad, So do I need more ducting towards the mini radiator ?
Should I change to the ralliart thermostat ?
Should I switch a more cfm fan maybe ?
92c was on a cool 20c day, when summer hits here again, I might overheat and this was at normal cruise speeds
ideas ?
Old Apr 21, 2010 | 03:16 PM
rh9's Avatar
rh9
Installed a new 3 row mini radiator because I can not fit the stock oem rad anymore after installed the 76mm turbo
water temps raise to 95c when I move and come down when I stop, Does anyone have pix of air ducts made to their evos to help force air through the radiator ?
Old Apr 21, 2010 | 03:27 PM
K1tt3n5's Avatar
What brand is your mini radiator? If its not a good one, contact cbrd for a nice solid mini radiator or a slim full size.
Old Apr 22, 2010 | 06:12 AM
rh9's Avatar
rh9
I used a koyo previosuly and it didn't work
I custom made one now, 3 rows, 55mm thick made outa copper with a SPAL puller fan and my temps go into the 90s when I move fast, as soon as I slow down It comes back to normal again
I have hard time fitting a full size rad now with a gt42r sized turbo ... a slim full size might work though
I want to know what ppl with mini radiators do for ducting ? I still have the ac and I'm not planning on cancelling it out in this heat
Old Apr 22, 2010 | 08:34 AM
CBRD's Avatar
our full size slim offers more clearance than a stock rad at both the core and the tanks,
i prefer full size rads where they can fit!
cheers
cb
Old Apr 22, 2010 | 12:01 PM
K1tt3n5's Avatar
cheers
cb
Go with this, I have one and it's a very quality piece.
Old Apr 23, 2010 | 02:18 PM
rh9's Avatar
rh9
cheers
cb
Too bad I saw your post too late, I just installed a normal lancer's rad, It's the same dimensions except thinner, works perfect cooling wise !
Old May 2, 2010 | 09:07 PM
LCS's Avatar
LCS
Cheaper solution?
