Twinscroll Update - Sierra Sierra Time attack Evo + Philthy's 2.3L twinscroll 4088R (
1) Sierra Sierra evo8 putting the Full-Race twinscroll through its paces during a practice session at Buttonwillow:
http://www.youtube.com/watch?v=7zsHa...layer_embedded
2) A hardcore Subaru customer of ours has a Full-Race twinscroll 40R turbokit on his daily driven (literally) built STI. He loves the spool, response and power but wanted to do a similar build to an Evo. He bought a low mileage evo8 from a close friend of ours, and decided to stay with the twinscroll turbokit to retain good spool and quick response, yet still looking for 700+HP. He used a simple but intelligent build with a top notch parts list. The first day of 93octane pump gas tuning was very impressive... resulting in 641whp/526tq
^^from the dyno
^^ the AEM log
Philthy's EVO 8 4G63 Built 2.3 Motor:
Full Race Twinscroll T4 Kit
Tial MVS (2-38mm)
Tial Q-BOV
Garrett GT4088R 1.06 AR
Headgames Motorworks Race Head
ID 1000cc Injectors
Kelford 280 cams (set at +2 intake, +1 exhaust)
Ferrea Valvetrain
Magnus V5 Intake Manifold
K1 Crank (Forged 4340 steel, core hardened, nitrided, mag-particle inspected, with straight oil holes for improved oiling to the rod journals)
K1 Rods (Forged 4340 steel, core hardened and mag-particle inspectedKiggly HLA Pressure Regulator)
Wiseco 1400HD Stroker Pistons (.020 over, 9.0 Compression Ratio with .225” wall tool steel pins)
Spark Tech Pro CDI 14 System
AEM EMS (Currently on V1 - Gen2 Box is on the way) w/ 5 Bar Map
EVO 12-tooth Crank Trigger Disc
ARP L19 Head studs and Main studs
AMS Race Balance Shaft Eliminator Kit
AMS Surge Tank (upgrade the walbros to Bosch 044 externals)
AMS Fuel Rail
AMS Small Battery Kit
AMS Test Pipe
AMS Oil Pan
AMS Intercooler
APR Strut Tower Bar
ATI Super Damper
Boomba 75 MM Throttle body
2.5" Intercooler Piping
Defi Water Temp, EGT, Oil Temp gauges
Exedy TwinHD Clutch
Fuelab FPR
HKS Cam Gears (set to +2 intake, +1 exhaust)
HKS Cat-Back Exhaust
4" Aluminum intake + K&N Air Filter
Koyo Radiator
Mishimoto Race Thermostat
ShepTrans
- EVO 9 1st gear ratio
- REM ISF Process
- REM ISF Sleeves
- REM ISF Hub, Sleeves and Shifter Rails
Shepherd Racing Stage 3 Transfer Case
- Quaife LSD front diff
- 8mm to 10mm bolt upgrade
- New seals and o-rings
- Reshimming
- Neodymium magnet
- REM ISF Process
Spal Low Profile Electric Fan
Torque Solution Engine Mounts
Peterson Oil Catch Can
^^from the dyno
^^ the AEM log
Tial MVS (2-38mm)
Tial Q-BOV
ID 1000cc Injectors
Ferrea Valvetrain
AMS Fuel Rail
AMS Test Pipe
AMS Oil Pan
AMS Intercooler
APR Strut Tower Bar
ATI Super Damper
Exedy TwinHD Clutch
Fuelab FPR
Koyo Radiator
ShepTrans
- REM ISF Process
- REM ISF Sleeves
- Reshimming
- Neodymium magnet
- REM ISF Process
As a fellow GT4088 owner myself I am impressed with the results once again. Did you post the boost somewhere. I was unable to find it.
Going over the list we have just a few parts slightly different but for the most part they are identical.
Congrats.
Congrats.
