AWD Motorsports "BASTARD" EVO.. 1st Stock Frame 700+hp FP BLACK!!!!
UPDATE*
Track times on 1st pass.. 9.33@146mph
Youtube Video
http://www.youtube.com/watch?v=n4-4tSrQOWc
We have been fighting thru quite a bit of issues with the car and some bad luck.. 1st we got a double pumper back from a customer that we used in the car without looking close enough and found the Siphon Tube on backwards and 1/2 the gas tank empty.. That ate 1 head gasket.. Then we had a head gasket that was miscut at the machine shop for the 4g64 motor which ate another head gasket.. So this week hasnt been our week..
However we kept trucking along to get the car into the 700whp range on the FP Black and tonight we did it.. It took 40.5psi to get the job done but we broke into the 700hp range with a 719whp @ 631tq pull @ 40.6psi..
We also added a Shearer 02 Dump and 44mm wastegate to help better regulate the boost.. With the 44mm Wastegate we found we could better regulate boost on lower boost levels by not having to put a crap load of preload on the stock actuator which wouldn't allow us to run 23psi and still get us up to 40psi..
We also Maxed the injectors tonight as well.. The car is at 97% duty cycle on PTE 1200s.. So we are done for HP at this point.. Next we will test it out at the track!!!
Mods List
4g64 Engine w/ Evo IX head.. Buschur Spec Internals
Cosworth m2 Cams
FP Black AWD Ported
Buschur Double Pumper w/ 1200cc Injectors
E85 pump Fuel
Buschur Ported Intake Manifold & TB
Buschur Ported Exhaust Manifold
Buschur Cop Ignition
Buschur Race FMIC
Buschur Turbo Back Exhaust
Shearer Vband 02 Dump w/ 44mm Wastegate
DC Sports Downpipe / Test Pipe
AWD Mini Battery Kit
AWD UICP & LICP
Stock fuel Rail
Stock Ecu w/ MAF Tuned By: Diiirk
Youtube Video
Mods List
Cosworth m2 Cams
FP Black AWD Ported
E85 pump Fuel
Buschur Race FMIC
AWD UICP & LICP
Stock fuel Rail
Basically on the dump tube side a pipe comes of flange and connects 44mm WG that has a dump tube off of it.. Flapper was modded and i have few more ideas to make it spool quicker we will try as well..
Mike
