will No cat make a big difference??
Old Mar 3, 2010 | 12:00 PM
Bergen Automotive's Avatar
So i have a invidia o2, downpipe, and HKS cat-back, but i have not removed the cat and replaced it with a straight pipe or resonater because of the car's warranty, what exactly will be voided if i change the cat?? and is removing the cat and putting in a resonater make a big difference? in sound?performance? or just leave the stock cat as is. I thought about it and kinda makes no since to have the o2,downpipe,and exhaust if the cat is restricting everything? thanks
also, what is the difference between a test pipe and a resonater??
Old Mar 3, 2010 | 12:24 PM
Kracka's Avatar
The stock cat is one of the most restrictive parts of the stock exhaust.
Old Mar 3, 2010 | 12:26 PM
gsrboi80's Avatar
People run cats on their evos?? I don't believe it
Usually dealers will tell you anything post cat is ok but precat is not
Old Mar 3, 2010 | 12:29 PM
so its restricting all the work the o2 and downpipe are doing?
Old Mar 3, 2010 | 12:30 PM
UT_Evo's Avatar
Most definitely. Get a 100 cell high-flow. All problems solved, and no new problems
Also, your warranty is already void, you modded your car. Welcome to Mitsubishi.
Old Mar 3, 2010 | 12:47 PM
my dealer replaced my transfer case, brembos,and bilsteins already with the o2,downpipe,exhaust,intake, and new bov installed, so they do replace things under warranty for me, im just wondering why the cat would be a good deal.
Old Mar 3, 2010 | 01:20 PM
ravnos04's Avatar
No cat def sounds beefier. Not too obnoxious, but like your car has some ****s.
Old Mar 3, 2010 | 01:28 PM
UT_Evo's Avatar
Then you're lucky, Mitsubishi wouldn't. If they replace it with all that stuff, the cat shouldn't make a difference as long as you still have one (ie, high flow).
Old Mar 3, 2010 | 01:35 PM
mdsevo06's Avatar
Depends on if you like the smell of exhaust at every stop light. But after switching to E85, it's smells sweet. There's good gains from this and the turbo loves less back pressure, but you do take a risk with smog laws. I've been running catless for three years with zero issues...knock on wood.
Old Mar 3, 2010 | 01:36 PM
what about a resonater, what is the difference between the test pipe and a resonater?
Old Mar 3, 2010 | 01:52 PM
Davo's Avatar
Test pipe is a straight through piece of pipe with the flange at each end to bolt back to stock exhaust.
Resonated pipe is a resonator with same flange to bolt back up
Resonated pipe are supposed to make the exhaust quieter than a test pipe by shear fact of having a resonator in it.
I went resonated(Megan) as I didn't want noise with baby inside.
turbotalawd's Avatar
A test pipe completely replaces the catalytic converter with a hollow pipe just like the rest of your exhaust. It's for "off-road" use only (catch my drift?).
People add resonators to their exhaust systems to lower the noise. Its a little restirction but not as big a restriciton as the stock cat. A resonator will NOT help you pass emissions because its not a cat.
Old Mar 3, 2010 | 01:55 PM
so resonater will still make a smell like the test pipe?
Old Mar 3, 2010 | 02:01 PM
mdsevo06's Avatar
It all smells the same....I went Megan as well.
Old Mar 3, 2010 | 02:22 PM
FQ-300's Avatar
Emissions = Hi-Flow Cat (Mil-Spec 100 Cell)
Non-Emissions = Resonated Testpipe
Increase in sound and power with both options.
