Buschur Racing Dual Stage Boost controllers!!
Old Mar 9, 2010 | 02:11 PM
Conrad's Avatar
Nice piece of kit Dave
Old Mar 9, 2010 | 04:46 PM
David Buschur's Avatar
The pricing on these is set very close to as low as we can get them. The solenoids are EXPENSIVE and that's why we haven't built more in about a year. I'm not even sure there is going to be a dealer price on these because of that.
Thanks for the good words.
Old Mar 9, 2010 | 05:15 PM
EvoDan2004's Avatar
dave can this be setup with stock ecu?
maybe i missed it but how does it know what gear your in to change from low to high boost??
Old Mar 9, 2010 | 07:01 PM
05ah8james's Avatar
It can be setup with anything, it runs off of a 12v source. I'm not positive on the boost by gear like me mentioned, but Im sure you would have to splice the 12v source into a specific wire in the ecu harness and you'd set up a trigger via Tephra.
Old Mar 9, 2010 | 08:09 PM
red03evo's Avatar
Awesome.
I will be getting one of these soon.
Old Mar 9, 2010 | 08:24 PM
cij911's Avatar
Dave - Why go this route (MBC) over the ECU controlled boost ? Your design sounds nice and I am sure I am missing something, but can't the ECU controlled boost do the same thing ?
Old Mar 9, 2010 | 08:49 PM
06MREvo's Avatar
Very very nice DB...once I live in an area where E85 is readily available this would great if I had to switch from 93 & e85...
Old Mar 10, 2010 | 02:02 PM
You do not have to switch 12v, you can also switch the ground, which many times is easier to do.
In the AEM, Haltech, ViPEC etc., you can trigger things through vehicle speed. The stock ECU I'd guess can do the same thing but you'll need to get info from Tephra.
If you want to use ECU controlled boost by all means do that. I've found it to be annoying and a PITA, so I stick with manual controllers.
Old Mar 10, 2010 | 02:08 PM
Complete product picture added to first post.
Old Mar 10, 2010 | 02:11 PM
badev0's Avatar
Looks great David. I will definitely pick one of these up in the future.
Old Mar 10, 2010 | 02:17 PM
For reference I have 10 units now. Whether or not we make more will depend on how quickly these 10 move and availability of the solenoids again.
Old Mar 10, 2010 | 06:18 PM
burnzy's Avatar
Originally Posted by scheides
Awesome on the locking mechanism! This was always my biggest gripe with all of the inline MBC's, including yours (apparently an older version).
Does the solenoid run on 5v or 12v? The Aquamist has a 5v output for failsafe; currently I have this wired into my stock ecu for mapswitching and it uses a GM BCS to control the boost (more info here), but I suppose this 5v could go to the solenoid as well as the ecu input for switching boost at the same time as switching fuel/timing maps.
Hrm, mebbe a summer project.
aquamist also has the relay, you could most likely use that to triger hi/lo boost instead of the 5v out, thats how I'm controlling my avcr so that it doesn't drop to wastegate on failsafe but drops to a level I control it to.
I have 5v to ecu to switch maps and the scramble switch on the avcr connected to the relay which shunts to ground on failsafe.
Almost certain this one can be rigged one side on NO and one side NC for hi/lo boost through aquamist.
Old Mar 10, 2010 | 11:50 PM
Johnboy1065's Avatar
very nice boost controller. I've used mine for over a year now. No problems at all!
Old Mar 13, 2010 | 12:54 AM
The only problem with yours Johnboy is we need to TURN IT UP HIGHER!! hahaha
Old Mar 13, 2010 | 09:52 AM
KTriplett's Avatar
saw one of these in person for the first time on erics car a few weeks ago. very clean install look awesome in the bay. great stuff.
