Engine oil leak w/pics
Old Mar 12, 2010 | 02:30 PM
dryad001's Avatar
So Im trying to find this leak from somewhere. At first I thought it was either the front main seal or the oil pump shaft seal but those are bone dry. But I did find something that I just can't figure out.
This is looking from the bottom to the top. The arm that the tensioner pulley sits on has a big oil drip coming from it. Deos this bolt go into the crankcase somehow? Possible location (bolt) that is causing the leak? I know it pivots that rides on the hyd tensioner.
This is looking up a bit farther. It should be the bottom of the engine mount bracket. The bottom of it is wet with oil but the top of the mount is dry.
Any ideas anyone?
Just letting the car run about 5 min there is a streak of oil from hitting the belt and spewing oil everywhere.
Old Mar 12, 2010 | 02:43 PM
barneyb's Avatar
The leaking bolt goes into an oil gallery. Remove, apply sealant to the threads and replace.
Old Mar 12, 2010 | 02:51 PM
dryad001's Avatar
Thanks a lot. Time to pull the timing belt.
Old Mar 12, 2010 | 05:10 PM
dryad001's Avatar
Nope, that doesn't go into any oil galley. I used a q-tip to dry out the threads and nothing came back out.
On the tensioner arm, is there any type of sealant that goes on the back side or some type of gasket?
Old Mar 13, 2010 | 09:59 AM
barneyb's Avatar
https://www.evolutionm.net/forums/ev...t-install.html
Old Mar 16, 2010 | 10:45 AM
mega-z's Avatar
^what he said, i had the same problem. =P
Old Mar 16, 2010 | 10:56 AM
dryad001's Avatar
I have all the bolts with rtv on them. I will start the car after I get a new VC gasket, mine ripped when I took it off last night.
Adio
For Sale - Cars For Sale
Apr 16, 2014 09:09 PM
JDMEVOLEX
Feb 17, 2014 03:49 PM
LVSBB6
Feb 23, 2012 08:57 AM
LVSBB6
Aug 23, 2011 08:21 PM
dryad001
Apr 28, 2011 12:55 AM
