Evo9 mivec problems help me out ???
Old Mar 16, 2010 | 04:01 PM
evolution9kidd's Avatar
Question Evo9 mivec problems help me out ???
Ok so my head starts knocking so I change my oil figure oil is worn out and needs a change... Come to find out anti freeze and water don't mix good ... So I started to take my head off but first out with the radiAtor , alot of oil build up in there so then get the head off and come to find out blown head gasket lol.... Then I take a look at the pistons and every single intake valve was tapping Against the pistons...
? Due to basically water as oil could that of made the oil feed to the mivec intake cam gear loose oil pressure and the key / gear inside give way then make the cam skip a tooth in timing then obviously making the valves tap the pistons ...
Or does anyone know any info on the mivec cams gear
Thanks for the help
Old Mar 16, 2010 | 04:12 PM
HellloOooooooooo
Old Mar 16, 2010 | 04:34 PM
Loooo somone help
Old Mar 16, 2010 | 05:03 PM
20gmr's Avatar
I think Using the cometic headgasket may have caused your issue. VIII and IX headgaskets are not the same. Ix's are thicker and also have smaller oil feed holes due to the added oil supply line.
As far as the mivec gear goes there isn't much to know.its basically an oil filled clutch and i don't beleive it can travel far enough in either direction to clash.
Old Mar 16, 2010 | 08:06 PM
I have a 9 and used a 9 cometic headgasket so ???
Old Mar 16, 2010 | 08:07 PM
What kind of head gasket does everyone recomend for my build ... build is in my signature ...!
Old Mar 17, 2010 | 02:19 PM
Mike.p's Avatar
you can use a VIII headgasket on a IX with no problems.......
Old Mar 17, 2010 | 02:20 PM
Mike.p's Avatar
stock...everyone will tell you..also search and youll see what i mean
Old Mar 24, 2010 | 07:12 AM
Half the people say stock and half the people say after market so let me get some more opinions !!!
Old Mar 24, 2010 | 09:25 AM
20gmr's Avatar
pretty much everyone says stock for a ix. Cometic lists their headgasket for an viii or ix. Yeah I guess it would work but isn't proper, the gaskets are different tho atleast between oem.
Old Mar 24, 2010 | 09:31 AM
hamx0r's Avatar
Sean@Iveytune recommends the HKS headgasket 1.3mm(i believe) for the evo 9... thats what i have in my car...
EVOkeeper
Jun 22, 2014 08:43 PM
overdrive1
May 15, 2014 09:52 AM
overdrive1
May 14, 2014 10:39 AM
Waz996
Sep 5, 2008 10:14 AM
Tuner@Swift
Aug 6, 2008 05:38 PM
