"hissing" sound and boost is down but no leaks
I wish, all I need is a mongoose to fix LOL.
If a boost leak check means running 2 bar of compressed air from the hot side of the IC to check for leaks, then yes we did a boost leak check.
I took off the intake pipe and checked the turbo impeller, found no play and spin was good. Will probably pull out the whole turbo to check the hot side. Will also try a wastegate swap.
@ Blazing VIII /mifesto
Boost leak check from turbo inlet, j pipe and the wastegate check sounds like the next things to do before I take down the turbo.
@IrightI
airbox ARC
Thanks guys!
@IrightI
airbox ARC
Thanks guys!
