Figuring out cfm flow numbers for our 4g63's
Old Nov 5, 2003 | 07:54 PM
Secret Chimp's Avatar
Question Figuring out cfm flow numbers for our 4g63's
How do you figure out the cfm flow numbers for our Evo engine?
I know how to figure out the flow for a na engine. But I am not sure how to compensate for the turbo and the additional flow it creates. Anyone know?
SC~
Old Nov 6, 2003 | 08:26 AM
Dale_K's Avatar
The December issue of Hot Rod magazine has an article about turbos and part of it touches on your question. I couldn't find it on their web site but it is definitely in the Dec. mag. The major variable is volumetric efficiency. At 100% cfm is a pure calculation based on displacement and rpm. They say assume at least 100% for a turbo motor. They are measuring air flow in pounds per minute, not cfm and have conversion factors, etc. Really good article and this is only part 1 of 3.
Old Nov 6, 2003 | 09:56 AM
aaronyoung's Avatar
the air flow formula is
CDI * rpm * VE * .5
.... ....1728
to arrive at CDI take CC and divide by 16.4
VE is usually in the .9 (90%) range
that will give you naturally aspirated airflow in CFM
to arrive at a boosted CFM
multiply the NA air flow number by the pressure patio (PR)
PR= 14.5 + boost pressure (in psi)
.... .... ...14.5
so a boost pressure of 14.5psi or one bar would have a pressure ratio of 2
have fun plugging away
aaron
edit: if you are trying to plot compressor maps you might need to convert your final number into lb/min.
to do so multiply by .0691
Old Nov 6, 2003 | 11:18 AM
Thats some good info Dale/ Aaron. Thanks.
I'm going through this exercise to figure out what kind of intercooler is needed for our engines. I found a site that custom builds intercoolers...but they list the applications by air flow needs.
Plus I am building a Turbo Austin Mini at home right now. And I'll need to eventually get an intercooler for the 1.3L engine. And it has to be a custom built one due to the size constraints of the engine compartment.....
SC~
Old Nov 6, 2003 | 11:53 AM
SuperchargedGTZ's Avatar
dont know if it is relevant but when i have done datalogging with my scanner, at full WOT i have seen around 29 t0 31 lb/min of air flow
Old Nov 6, 2003 | 12:35 PM
aaronyoung's Avatar
that is about right,
just for chits and giggles...
What was your boost pressure and rpm at that reading.
we might be able to calculate a true VE number for this engine.
edit: I will also need your elevation above sea level.
killerpenguin21
Jun 23, 2015 12:22 PM
AutoMotoSports
Oct 6, 2008 07:53 AM
Nihilanthic
Feb 9, 2005 10:18 PM
DRC Imports
33
Sep 12, 2003 09:14 AM
WannaRace
Feb 23, 2003 06:37 PM
