Slight "knock" after installing built shortblock
Old Apr 12, 2010 | 05:17 PM
Wht9er's Avatar
My mechanic took my car for a spin after putting in the new built shortblock. At the time he also installed my new GSC S3 (<-- could be relevant). He said around 3k rpm and under there is a very slight "knock." There is oil pressure...any ideas?
Old Apr 12, 2010 | 06:42 PM
jasonsrt4's Avatar
Forged Piston knock when cold, or knock all the time warm and cold? Lifter noise or lower end?
Old Apr 12, 2010 | 07:49 PM
n2oiroc's Avatar
do you have the motor specs? clearances?
Old Apr 12, 2010 | 09:14 PM
arnoldp's Avatar
If it stops "knocking" after the engine warms up the knock is likely just the pistons before they expand. That would be normal for an engine built for high performance.
Old Apr 12, 2010 | 09:24 PM
evowario's Avatar
sounds like its your lifter.. bleed them.... should fix your problem
Old Apr 13, 2010 | 07:01 PM
Wht9er's Avatar
just picked the car up...it seems to be my twin disc (comp twin) making the noise. it seems to only happen when i accelerate from 2000 to 2800 rpm, other than that no noise also i have put almost 100 miles on it, so if it were the rod bearings, it would have already happened. i think my mechanic was just being overly cautious.
Old Apr 13, 2010 | 07:25 PM
4g63smokinall4s's Avatar
really?
it amazes me how people comment on things on here and have no idea what their talking about...
op sounds like the clutch..
Old Apr 15, 2010 | 09:09 PM
SnyperZ's Avatar
Noise also goes away when clutch is depressed in same rpm range where it makes the noise.
Old Apr 16, 2010 | 08:09 AM
Teal2nnr's Avatar
Originally Posted by 4g63smokinall4s
really?
In reality though, trying to diagnose an issue with a car over the Internet is itself a futile effort. However you can get good ideas on things to check.
EvO_essence
Apr 26, 2016 12:10 PM
damie45
Apr 5, 2011 11:28 AM
Ted B
Jun 13, 2010 09:16 AM
gl4662
For Sale - Cars For Sale
27
Feb 29, 2008 04:27 PM
jasburbak
Sep 28, 2005 08:21 AM
