Shifter suddenly sluggish
Old Jun 5, 2010 | 03:31 PM
DFelton's Avatar
I had my clutch replaced with an exedy sd twin a few thousand miles ago, but lately the shifting, which has been beautiful, felt like peanut butter. Its really tough to go from 1-2 and 2-3 but the rest are fine.
Also, my pedal engagement for the new clutch in at the very very very top. What's that all about?
BTW, I searched, I failed.
-Doug
Old Jun 5, 2010 | 07:45 PM
hitman28's Avatar
shifter bushings? need more info. could be the tob. is it push or pull type?
Old Jun 6, 2010 | 03:06 PM
DFelton's Avatar
Thanks for responding. It has Buschur metal shifter bushings and is the standard style, pull I think. I just got the Buschur fork stopper in the mail, what a pita it would be if it's the tob.
Old Jun 6, 2010 | 03:55 PM
Kerr's Avatar
Fomer Vendor
Lube the shifter bushings.
Old Jun 12, 2010 | 01:07 PM
SavEVOIX's Avatar
Was there a solution to this problem?
I just installed my Exedy Twin and it engages perfectly but my shifter is so notcy and hard to get in to gear. I am going to try some grease in hopes this will fix the issue.
Old Sep 1, 2010 | 06:02 AM
DFelton's Avatar
I sprayed a TON of wd 40 on the linkage and that did it. It shifts so smooth now!
Old Sep 1, 2010 | 11:52 AM
mifesto's Avatar
wd40 is a temporary solution as it doesnt stand up well to engine heat and is fairly a thin lube. i'd still go through the trouble of removing your aftermarket shift bushings and lubing them up well.
Old Sep 1, 2010 | 03:16 PM
mollett89's Avatar
what kind of lube is best
Old Sep 1, 2010 | 03:23 PM
mifesto's Avatar
Antiseize will work. Interestingly so will motor oil if u think about it. It has good viscousity, great temp resistance, and made for such things.
Old Sep 4, 2010 | 08:23 AM
rsboy's Avatar
White lithium grease will work really well. Also add some to the shifter itself.
Old Sep 4, 2010 | 09:45 AM
DFelton's Avatar
I sprayed the WD40 on it at the beginning of the summer and it's still smooooooth. No doubt that grease, oil, anti seize would work better and last longer though.
AWDTFTW
Jun 21, 2015 05:39 PM
GSX 911
Sep 23, 2013 05:43 AM
ugakirk
14
Apr 14, 2011 09:11 PM
babu_rashu
Mar 16, 2011 11:35 AM
clubEVO93
11
Jan 3, 2011 06:05 AM
