throttle body leak?
Old Jun 20, 2010 | 06:16 PM
sivs's Avatar
throttle body leak?
my TB is leaking in the lower bottom left of the pic crosshaired below the green batteries and to the left of the P. It looks like a hole, WTF is it and why leaking there?
Old Jun 20, 2010 | 06:20 PM
1NastyMR's Avatar
Shouldn't leak from there?? That hole should have a screw in it which is used to adjust idle I believe?
Old Jun 20, 2010 | 06:26 PM
sivs's Avatar
theres no threads there though?
Old Jun 20, 2010 | 06:27 PM
apagan01's Avatar
make sure is not shaft seals, common issue. milspec seals resolved my issues in that area highly reccomend them.
Old Jun 20, 2010 | 06:33 PM
sivs's Avatar
i have them on order from milspec but this leak is different. Is this for the idle adjustment and if so can this seal be replaced easily?. This seal would be different from the shaft seals
Old Jun 20, 2010 | 06:41 PM
sivs's Avatar
it actually looks like its an o ring for the idle set screw. Anyone have a part # for this for an 03 evo. getting tuned in 2 weeks and need this fixed
Old Jun 20, 2010 | 06:49 PM
gsrboi80's Avatar
Couldn't find a part through mitsu (for the evo). Only the full throttle body and the gasket.
May wanna try to get one used on here if it's not just the shaft seals.
Old Jun 20, 2010 | 07:48 PM
asubennett's Avatar
Doing the shaft seals tommorow evening.
What is odd is I am holding and making boost fine, but I can still hear air leaking at this point. Curious to see if the leaking air here is acutllly impacting boost. I no that sounds counterintuitive. But the car is making boost fine with comparable load values to boot pressure on the logs.
Should be interesting. To the OP, I am having a hard time understand exact hole you are pointing at. You should circle in on the photo.
Old Jun 20, 2010 | 08:03 PM
Evoryder's Avatar
He's referring to the factory hole where the biss plug is(nice sized hole to the left of the "P". This should not be leaking, never heard of a leak there.
O.P have you pressure tested with soapy water? 99% of the time it's the shaft seals.
Old Jun 21, 2010 | 04:13 PM
sivs's Avatar
just called mitsu today i will get a new screw and o ring for the TB. Ill list part numbers when i get them. Everyone else should put soap down this hole also while doing the shaft seals. Im curious if there are more leaks out there. Messed up thing is my shaft seals were not leaking just the set screw o ring. Guess just my luck!
Old Jun 21, 2010 | 05:14 PM
Erik@MIL.SPEC's Avatar
Take a look at these wonderful BISS screws:
One in the middle is new. The other two came off customer TB's.
This is why MIL.SPEC has been replacing the BISS screw in all new MIL.SPEC 65mm TB's for awhile
Don't know if that's the issue you're having, but I thought I'd throw it out there.
Old Jun 21, 2010 | 06:23 PM
sivs's Avatar
exactly my problem. I just got ur shaft seals today actually so ill be all set, You guys should offer the screw and oring with ur seal kits too!!!
lbwilliams44
17
Oct 31, 2018 10:09 AM
Kryptyk_
Jun 26, 2017 11:33 AM
MetalMoshpit
Mar 17, 2016 06:23 AM
bowlersp
Sep 8, 2010 08:42 AM
CrackerJackToy
Nov 21, 2007 09:36 AM
