RS and Evo 8 tranny
RS and Evo 8 tranny
can anyone plz explain to me difference between this two gearboxes?
as I know top speed on RS tranny is a bit smaller, but can any one gve me numbers of 1-5th speed on RS
thanks
thanks
USA EVO 8 MODEL:
1st 2.928
2nd gear ratio 1.950
3rd gear ratio 1.407
4th gear ratio 1.031
5th gear ratio 0.720
reverse gear 3.416
final gear ratio 4.529
jdm evo close ratio:
1st gear ratio 2.785
3rd gear ratio 1.444
4th gear ratio 1.096
5th gear ratio 0.825
reverse gear 3.416
EVO IX 5spd
Final Drive Ratio 4.529
1st Gear 2.785
2nd Gear 1.95
3rd Gear 1.444
4th Gear 1.096
5th Gear 0.761
this one is an easy search...It should say it in your owners manual otherwise. I also just noticed you have a UK model...
1st 2.928
reverse gear 3.416
reverse gear 3.416
EVO IX 5spd
1st Gear 2.785
2nd Gear 1.95
3rd Gear 1.444
4th Gear 1.096
5th Gear 0.761
The USDM RS Evo gearbox does not, in fact, have RS specific gear ratios. The USDM RS model Evos share the wider spaced ratos found on the USDM GSR 5-spd.
AFAIK, for non-US markets, there are three different RS gearboxes available from the factory. There is a "short" box, a "medium" box, and a "long" box. You will find more info on LancerRegister as the British cousins do have access to all three RS boxes. I am not sure whether the only difference between the three levels of RS boxes is strictly dependent on different final drive ratios or the cogs themselves are actually spaced differently.
