The HKS T51R SPL is in...
Old Nov 20, 2003 | 02:55 PM
Boost Solutions's Avatar
Originally posted by stvbreal
75 shot will fix tha problem. 3k RPM full spool up
So the 100 will do it
George
Old Nov 20, 2003 | 02:57 PM
Originally posted by BPUKiller
Damn I had a T-51 in my supra, and it was a little laggy, but I put 600 to the ground, I wonder how it feels in a 4-banger?
Sam
600rwhp at 19-20psi?
Old Nov 20, 2003 | 07:08 PM
molton's Avatar
what happened to 1000hp?
Old Nov 20, 2003 | 07:15 PM
Alfriedesq's Avatar
Dont worry - that turbo will make some serious power !!!
Old Nov 20, 2003 | 07:40 PM
The efficiency of that turbo is from 25psi up
George
Old Nov 20, 2003 | 07:42 PM
I think 600whp at low 19 psi boost with pump gas is enough
Old Nov 20, 2003 | 07:43 PM
5StarSuzuki's Avatar
In Timeout
No way...600Hp on pump gas... I'll believe it when i see it.
Old Nov 20, 2003 | 07:46 PM
2fast2Furious's Avatar
In Timeout
I would like to see it as well. lolrof, no way you can do 600whp on pump gas. maybe if they install that 50whp B&B. That's a start.
Old Nov 20, 2003 | 07:54 PM
Alfriedesq's Avatar
I have no doubt it will yeild mega power if the car has enough fuel - however the issue is how many rpms to spool it up ??
Old Nov 20, 2003 | 08:07 PM
C-Murdock's Avatar
like someone else said no one will make 600hp on a 4cyl on pump gas. Id pay to see it.
Old Nov 20, 2003 | 10:39 PM
BPUKiller's Avatar
2.2 Bar, with 19-20 PSI it ran about 500 to the wheels.
Sam
Old Nov 20, 2003 | 10:42 PM
In Timeout
I heard that Boost Solutions has a supra and 300zx that have not been running in about a year in that shop? Also when you getting that skyline?
Old Nov 20, 2003 | 11:00 PM
drmosh's Avatar
If I remember correctly, the T51R is only at 90% spool rate at 8000 RPM.
How many psi is that?
Old Nov 20, 2003 | 11:31 PM
JeffWels's Avatar
why run the IC pipes over the exhaust mani, won't that just bake the IC pipe? regardless i also creamed my pants
Old Nov 21, 2003 | 12:01 AM
slowTsi's Avatar
HORSE ****! Without nos spool up is going to be close to 7000, depending on the ar. Not to mention it would surge like crazy nut sack if it spooled that quickly.
On an rb26det, The t51 KIA (smaller than the SPL) spools around 5500 prms. Now figure you have a larger turbo with 30% less displacement......
neat toy though
