Is 2.3L Strk Engine Harder on the Drivetrain...
Just like to know if I decide to drag with the car
Is it 2.3L stroker engine much harder on the Tranny & Transfer case then If I decide to rebuilt my 2.0L to drag specs ?
Which would last longer in the long run or is there not much of a difference ?
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
If you want more torque but still want to rev it out, a 2.1 may not be a bad choice.
As far as which one will last longer, it really depends on how you drive the car and how its maintained. Torque is what kills drivetrains however so does driver abuse.
2.3 is good for spoolin huge turbos, at lower rpm's and it can be good for drag racing but you just can not rev it to 10,000 rpm like the 2.0 and 2.1. So if you want to achieve the results of a 2.0, you might have to change the gear ratios, and make them taller, since you can not rev that high.
Mike
John Shepard has a 2.3 in his personal evo and with a 3586 runs 9.5's at 151. I think that is pretty good for a 2.3, but I also would like to see it with a little bigger turbo?? I think the 2.3 is a good motor with the right gearing in the trans.
....fun factor = 11 !
