What size injectors with fp red
Old Sep 15, 2010 | 09:23 AM
murderedevo256's Avatar
I plan on getting an fp red pretty soon, and I need some injectors for them. I will be running on pump gas for the most part, but will be doing an E85 map for track days. Im still on a stock motor so Im not breaking any records but still need enough flow. I was thinkin rc 1200's? I would love to go to id 2000's but I cant see spending that much without doing a full build. Thanks!
Old Sep 15, 2010 | 10:13 AM
grillpt's Avatar
I would say 1200's and a double pumper if your gonna run E85 at some point.
Old Sep 15, 2010 | 11:56 AM
sparky's Avatar
I would do 1450's for E-85.
Old Sep 15, 2010 | 12:32 PM
RockmanX's Avatar
mostly on pump i would say 1000-1200 would be fine since your not going to be on e85 often enough to care.
Old Sep 15, 2010 | 04:31 PM
YogSaahoth's Avatar
Veteran: Army
check this out...u can base ur choice on how much power u plan to make in the future
https://www.evolutionm.net/forums/ev...-can-help.html
Old Sep 15, 2010 | 04:38 PM
Tuxevo's Avatar
Stock block should be good with a single walboro and 1200cc. That should be plenty to edge at the limit of the factory internals.
Old Sep 17, 2010 | 02:55 PM
Mellon Racing's Avatar
I recommend the FIC 1450's and single walbro if you're on a budget. Later you can do the twin pump and built motor and have enough to support about 700awhp
Old Sep 17, 2010 | 06:44 PM
TK40's Avatar
Do you think the new FiC 1100's will work on a 93/E85 tune, or are they too small for E85?
Old Sep 17, 2010 | 07:11 PM
milford's Avatar
keep the red at 12lbs and you can get away with 500s and half a pump....seriously the levels of knowledge present in the thread are so vast its scary.. to think these people are driving on the same roads as the rest of us is terrifying... give petey a call and get some worth answers.
Old Sep 18, 2010 | 12:42 AM
depends on your horsepower goal, but if you're referring to the OP, they'd be a little small for him.
Don Q
10
Jan 23, 2011 12:36 PM
rEVOlution04
132
Aug 4, 2010 09:11 AM
JDMonster
13
Apr 15, 2010 08:05 AM
bbyevo8u
24
Dec 6, 2009 05:55 PM
BorisTheBlade
15
Sep 27, 2008 09:59 AM
