new build, not fireing
well as it says. 06 iX, 2.4(mods in sig.)
just got everything together, and after check and double checking everything, well.... shes not fireing.
we pulled the fuel line, theres fuel.(in the lines, injectors not running,...)
we check for spark, theres spark.
we sparyed in starter fluid, fires, so theres comp/spark.
Injectors just arnt fireing,.. We cleared all codes and turned it over for away,.. no codes came back up..
then we checked to see if the Ex. cam angle sensor was 180*,... flipped it back and forth a couple times,... nada.
ANY IDEAS?!?!
ANY IDEAS?!?!
Found out what it was, thnx for the input though!
Im running a Fidanza Adj. cam gear on the exhaust cam. And it has two holes in it for the cam dowel, and like a normal person, i put it together with the dowel in the hole that has "EVO" on it,... WRONG ONE!
I've done so many sets of cams/head gasket/timing belt swaps, but its been awhile and forgot that at TDC, the cam dowels will but UP!
Another thing that hinted for me to check there was cuz the Ex. cam angle sensor at TDC wasnt at 3-4 o-clock.(the beeft side).
So anyways fixed the timing and all is good.
CLOSED.
