Please Advise - Will this affect Oil Suction?
Old Sep 25, 2010 | 06:52 PM
jameswwt's Avatar
Hi,
refer to the attached picture, can anyone advise will this affect the oil suction and how to resolve this problem?
My engine oil pan is not dented and just wonder why the pipe in the photo is touching the base of the oil pan?
Please advise how to resolve this problem.
Thank you.
Attached Thumbnails Please Advise - Will this affect Oil Suction?-21092010534.jpg
Old Sep 25, 2010 | 07:08 PM
KX250Fmotoracer's Avatar
Is that the stock pickup? That definitely has to be fixed
Old Sep 25, 2010 | 07:09 PM
jameswwt's Avatar
I think so and any idea how to fix it up for the sake of long term durability?
We actually suspect this is the main problem which affect my low oil pressure.
Old Sep 25, 2010 | 07:36 PM
Yea this would cause low oil pressure. Did you check all your bearings?
I would just try to give the pickup a little bit of a bend to get some clearance. If that doesn't work, you might want to give one of the more well known builders a call and ask if they've seen this before.
Old Sep 25, 2010 | 07:40 PM
JDM-Evo9MR's Avatar
i think you should replace that pickup. if that is not at the correct distance, you'll be in trouble.
Old Sep 26, 2010 | 12:20 AM
jameswwt's Avatar
Thanks guy but do anyone know what is the minimum clearance for the oil pickup to the oil pan base???
Old Sep 26, 2010 | 07:31 AM
barneyb's Avatar
I can diffidently say it isn't zero.
I'd suggest trying to find a way to check both the pickup and the pan from another engine. You might have gotten the wrong pan from the maker.
Old Sep 26, 2010 | 08:48 AM
Evo8luva's Avatar
I agree that this is causing your low pressure issue..
Your positive that your pan isn't dented, or the car was lifted from the pan by accident??
Old Sep 26, 2010 | 11:00 AM
jameswwt's Avatar
Im very sure the pan is not dented at all....Will try to figure out a way to make more way for the pickup clearance...
By any chance do anyone knows what is the clearance???
Old Sep 26, 2010 | 01:38 PM
94AWDcoupe's Avatar
your pan is dented. should be ~10mm clearance
Old Sep 26, 2010 | 06:14 PM
jameswwt's Avatar
Thank you so much guys...But yet, i cant see any dent....
Anyway, truly appreciate the info...
Thanks 94A
Old Sep 28, 2010 | 07:41 AM
jameswwt's Avatar
Hi Guys,
today my mech have cut out part of the Pickup as shown on my attached picture...
Will it have an advert effect for over cutting?
Attached Thumbnails Please Advise - Will this affect Oil Suction?-280920105421.jpg
Old Sep 28, 2010 | 08:41 AM
jameswwt's Avatar
Hi Guys,
Anyone to advise please....
Old Sep 28, 2010 | 09:08 AM
SWOLN's Avatar
Whoa, get a new pickup now. There will be loss of suction now, when the oil doesn't surround the entire gap opening in the pickup. You will not maintain oil pressure if that happens.
Old Sep 28, 2010 | 01:16 PM
94AWDcoupe's Avatar
The early 4g63 pickups look just like your cut one. So it is not a problem. Only if pan gets dented more it will be easier to starve pickup completely. I had a customer years ago that jacked his early 4g63 car up on oil pan for his first oil change. He had max of 30psi oil pressure and drove the car for two weeks before bearings got noisy and needed changing.
