High Idle after TB Seals
Old Oct 4, 2010 | 06:03 PM
JDavenport's Avatar
OK, this might be better in another place, but I'll start here.
The TB seals on my IX were leaking pretty good. So I got the Mil-Spec seals with the new TB gasket and did the replacement. I very carefully marked the TPS sensor against the throttle body during disassembly.
The car has 50k on it and the butterfly plate, shaft and engine side of the TB had some serious sticky carbon build up. So using some carb cleaner on a rag I cleaned everything up nicely before installing the Mil-SPec seals and re-assembling.
Using Evoscan, my TPS feedback at idle before the swap was 13.1. Afterwords it is now 12.9. I figured that is damn close
Car runs great, but now it idles at 1100 rpm's. Checked the throttle cable and yes the butterfly is going all the way closed against the stop. Is that 0.2 difference in the TPS reading at idle causing this? Since it is actually -0.2 wouldn't it idle lower?
What am I missing here?
Old Oct 4, 2010 | 08:18 PM
stackhouse's Avatar
Could have gummed up your IAC when you cleaned the TB. I'd check that out. And as always, check for the pesky vaccum leaks.The difference in TPS feedback could be due to the removal of the carbon buildup, I guess?
Hope this helps
Old Oct 5, 2010 | 05:21 AM
black95tt's Avatar
Did you clean EVERYTHING off the inside of the TB? Mitsubishi puts a small coating in there that if removed can mess with the idle. I believe they use molykote 321. Search on here for some more info.
Old Oct 5, 2010 | 05:25 AM
rdt1's Avatar
This sounds right!
Aby@MIL.SPEC
Mar 9, 2021 11:41 AM
Erik@MIL.SPEC
365
Aug 29, 2017 12:59 PM
Aby@MIL.SPEC
867
Mar 12, 2017 11:56 PM
EVO8emUp
Jun 21, 2013 03:37 AM
