Trans?clutch?
Old Oct 10, 2010 | 06:37 PM
Frank120's Avatar
Trans?clutch?
Got a question Evom members... If I shift from 1st to second under 3k rpms (if I put the clutch in fast) it makes a clunk noise is it normal?
Old Oct 10, 2010 | 06:43 PM
BluEVOIX's Avatar
Is this clunk coming from the rear? If so , then yes it is normal. The rear differential has soft rubber mounts that causes it to bounce and make that clunk noise. If you shift fast and release the clutch fast during a WOT pull, it will feel like someone hit the back of your seat with a sledge hammer.
Only way around it is to replace the diff support with aftermarket or shifter and release the clutch softer/smoother.
Unless your talking about a different clunk.
Old Oct 10, 2010 | 06:58 PM
Frank120's Avatar
No it's not that. It's comming from the front left. And yeah I just found out about that to.
Old Oct 10, 2010 | 07:16 PM
javicracer's Avatar
Tob
Old Oct 11, 2010 | 05:48 PM
Frank120's Avatar
And when I turn off the car it makes a rattle noise. Idk if it's a motor mount?
Old Oct 11, 2010 | 10:03 PM
CooleyKing's Avatar
throwout bearing? just a guess
JorgeAvila
Jan 13, 2015 02:02 PM
GSX 911
Sep 23, 2013 05:43 AM
swangdog
15
Jan 4, 2013 12:12 PM
bumblebee04
Apr 4, 2011 10:02 AM
