what year galant motor?
i am thinking about getting a 2.4l making it into 2.1L for my Evo and built it..
What year cars work?
What do i need for it too work in my Evo besides change the cam gears?
can someone send me links to where to destroke a motor? like were to buy the parts
what car should i get the 88mm crank shaft from? or where can i get it?
can i use my Evo Crank? or can i use it out of the car i pull it out of? or do i need a custom Crank?
If you mean the galant years block you need from the 2.4l its 1999-2003 or you can use the 2000-2005 eclipse block...Im doing a evo 8 head on my galant 2.4l block right now with adjustable cam gears.Thats really all you will need up top and an adaptor for the water pump...Now if you want a 2.1l thats a whole different story going inside the block
And the Galant is a 2.4L motor?
i could build either one and it will fit right in my Evo 8?
+1
IIRC a 2.4 block and a 88mm crank is a 2.1 destroked.
Good info here:
https://www.evolutionm.net/forums/ev...ot-stroke.html
Good info here:
I can get you part # for the crank if you want I think it cost about 400 bux from mitsu new. You might want to contact Mike@AWD on here, he has a bunch of cranks and can get you one at an extremely good price.
1996 Kia sonata
2003 eclipse
Various galants
I bought a 64 block in good condition from a junk yard for 350$.
Theres alot more years of those cars that the 4g64 comes in. 2g non turbo spyders have 4g64s, all 00-05 rs/gs eclipse have 4g64's, dodge stratus's, galants You can find a 4g64 block in almost every junk yard if you know what cars to look for.
If your looking for a DOHC 4g64 that you can use cam gears ect.. you can look for a 4g64 out of a KIA optima or a Hyundai Sonata 2.4l. these have a DOHC Mitsubishi head with the correct timing belt and cam gears .
