Post your Synapse DV config and results
#151
Thank you for all of the feedback. I'm sorry, we haven't been very active on the boards lately. We've been buried on some R&D that has us all pre-occupied.
Please let us know if you're having a hard time finding product, or getting adapter flanges. We've been going through the Tial adapter flanges faster than anticipated, but can direct you to the right place that will have it in stock.
I definitely suggest trying out pull mode. As I posted above...I am using the Tial flange too with the DV in pull mode using port B only...factory preload too...only time I've had any flutter is going up hill in 5th or 6th at low RPMS...The hill I went up I usually go up in 3rd gear...So unless I'm trying to make it flutter it won't do it...
Completely forgot about Fastenal. The closest one to my house is like 45mins+. I just ordered mine from some UK ebay dealer. Took a week to get here...
#152
Shouldn't have to go looking for parts to be able to install a high end DV kit. I got my friend to buy one for his Evo, and he was completely annoyed by the lack of any fittings in the kit that would allow the quick release hose assembly to attach to the factory hard pressure line. I had forgotten about his for my install because there were some fittings lying around the shop that made it easy to adapt.
#154
Shouldn't have to go looking for parts to be able to install a high end DV kit. I got my friend to buy one for his Evo, and he was completely annoyed by the lack of any fittings in the kit that would allow the quick release hose assembly to attach to the factory hard pressure line. I had forgotten about his because there were some fittings lying around the shop that made it easy to adapt.
#155
One thing I will say I don't like about the diverter valve is the design of the clamps that hold the flanges together, and the size of the o-rings. The bolts are small, appears weak, and simply doesnt seem to hold the flange to the bov with any force. Furthermore, the clamp doesnt seem to bring the flange and bov together. Its seems it fits into the slots just to prevent the flange from coming out. After bolting down the flange, I can still rotate it by hand. As mentioned by another post previously, I reused my TiAL o-ring instead of the one provided with the unit. The viton ring that TiAL uses are thicker and appears stronger. I would much rather see a redesign to use clamps similar to TiAL's design. Just my 2 cents.
I have not notice the fluttering issue going uphill in push mod. When I'm going uphill, 4th or 5th gear, and low rpm, and the car starts to build boost, the Synapse blows it off and my car doesnt buck like it used to. No fluttering at all. My boost gauge gause doens't go crazy, nor does the wideband. Don't know if that makes sense.
I agree with everything you said in the 1st paragraph and everything makes sense in the 2nd paragraph...haha
^^Thats the same way I had mine setup till my fittings came in...
#156
Once installed in push mode My booost jumped to over 30 psi when I was originally set to 26-27 psi. This thing is amazing and I would recommend this dv over any..[/QUOTE]
Isn't that a bad thing? if your tuned for 26-27 PSI and it jumps that high I thought that would be bad for the motor.
#158
he should get a retune and possibly turn the boost down.
#159
#160
In comparing to my Tial QR, I think this valve has much better crivability as far as partial throttle is concerned. The only reason I swapped was because of partial throttle bucking on the road course, which really upsets my car. Having read through the review on MotoIQ, I really believe what they mentioned was what I was experiencing...as my HKS turbo build boost during partial throttle modulation. The TiAL QR was perfect prior to my road course experience. I didn't have any flutter with it, but it definitely wasn't working well for part throttle. With the Synapse in my current configuration, it seems partial throttle on high was improved, and the car doesn't buck as I hold the throttle still after passing someone.
Based on some recent research projects that we have, I've been looking at some data and realized why bucking even happens. I can understand the root cause of why this issue happens, I think I can even try to explain why Synchronic helps fix the problem. WARNING: Long post coming
#162
To understand what really differentiates the Synchronic technology that is in the DV, we have to talk about reaction times. When connected straight to the intake manifold, Synchronic DV will react to a change in pressure in about ~25-30 milliseconds. The fastest a diaphragm BOV/DV reacts is about 200 ms, the slowest is 750 ms. This includes the piston units out there that have a brass or aluminum piston. Why is Synchronic so different, it is the geometry of our patented piston design that allows us to react so quickly. When used with a solenoid, Synchronic will actuate to full lift in as little as 15 ms.
Now, why do Evo's buck? The chart below is a trace of what surge looks like in raw data form plotted across time in milliseconds.
1- Blue- Intake manifold pressure, sourced after the throttle plate
2 - Orange - Air Speed - turbocharger inlet - equivalent to a MAF, very steppy because these $5k sensors only have a 50ms max resolution
3 - Red - Pre-Throttle, boost-only pressure
You can see that when the throttle plate closes (5), there is a significant pressure rise (4) in the intercooler piping. On this example, the base boost pressure is a mere 16 psi and spikes to as much as 21 psi. Take a close look at Air Speed (6) after the event. The airspeed hasn't changed because the momentum of the turbo, any turbo for that matter, cannot decelerate that quickly. There is still significant air mass being consumed by the turbo well over 200 ms after the throttle plate is already closed. This is airflow that the MAF is not only seeing, but calculating against and delivering fuel. So, even though, there really isn't any more aiflow going into the engine past the throttle plate, surge events force the MAF to read and subsequently deliver fuel against this data. The only solution is to have a very fast acting DV that can clip that pressure rise and airflow past the MAF.
Flutter, surge, or whatever you want to call it, is what is documented in (7) almost 400 ms after throttle closure. So, regardless of whether or not you hear flutter, the negative effects of a slow reacting DV are present.
Unfortunately, without any electronic controls to actuate the DV, you really can't get anything faster than 30 ms. Putting electronic control on non-synchronic DV's only improve them to about 150 ms reaction. Either way, Synchronic still enables fast reaction times, even in the absence of electronic control.
Equipment Used in Data:
DAQ - Motec @ 1000hz
Air Velocity - TSI Thermal Anemometer
Pressure transducer - MKS
Last edited by Synapse; May 7, 2011 at 09:28 AM. Reason: Added equipment list for anyone that wants to replicate data
#163
I think that what you are describing is one of several scenarios where bucking can occur. The scenario that is much more apt to cause bucking on my Evo is very slight part throttle lift after mild acceleration at low boost levels.
I have a good idea of what is causing it, at least in push mode. During mild acceleration, light boost pressure builds up in the charge piping (and IC). When slight throttle lift occurs the vacuum change in the manifold is enough to induce the DV to open, and this in turn causes the pressure in the charge piping to drop which in turn causes the airflow into the manifold to drop, and the motor momentarily loses some power. After the charge piping pressure drops, the differential pressure across the DV drops, the DV closes, boost pressure increases in the manifold, and the motor surges momentarily. The charge pressure again rises high enough to open the DV, and the motor momentarily loses power again.
The problem is that the movement of the DV piston is too much in these scenarios. It needs to be able to bleed off the pressure in a more proportional manner. I called you guys many months ago to suggest that an angled skirt on the DV piston to help control flow at small openings might be helpful. I imagine that getting this to work could be a challenge though. With differential pressure acting on the valve, 99% of the time there is either a net open or net closing pressure, and rarely are the pressures balanced.
The interesting thing is that I get some of the same type of bucking in pull mode where charge pressure and manifold boost both act to hold the DV piston shut. In pull mode, I would expect that once the charge pressure drops from initial DV opening, the charge pressure closing force would diminish, and the valve would open further rather than close back up. Perhaps there is some effect of false MAF readings on timing and AFR.
#164
#165
Do you sell the 1/8th npt back cap separately without the boost connect fittings? My kit didn't come with the brass barbs and I can't find low profile 1/8th bspt fittings anywhere. The boost connect doesn't fit evo boost nipple, so I had to rig a piece of hose ziptied over the boost connect tubing. I love my DV but I hate running it with this boost connect crap, especially running 35psi.
You guys need to make a hose nipple adapter to plug into the Y fitting, so we can use normal hose. IMO the barbs should be included with the kit since it's advertised in the picture for the kits.
- The hoses don't expand or collapse under boost/vacuum
- You don't need a special tool to cut them = razor blade
- They are positively retained by connectors as long as they are pushed in all the way
- they are easy to cut to length
- they don't leak and minimize any questions regarding leaking
- they are very modular
We've performed plenty of testing with these connectors and hoses and haven't encountered big problems, unless they aren't installed correctly. We use these on everything, not to mention that we sample data in the millisecond range and they are consistent performers down to the millisecond every single time they are used. Granted there are going to be reject parts every now and then. But they have been very reliable on the whole. We've also taken the time to make sure to engineer the proper materials that will survive and perform in this environment.
There are a couple of big NoNo's when using these fittings and hoses. You need to give them some bend radius, they can't go very tight or they kink. Below are pics of an installation that I saw once, and obviously, they leaked in that situation.
You have to give them some slack. And when you do, they actually work to absorb a good amount of vibration in the system. Don't worry too much about hose length. They don't expand under boost so they get the signal to the devices very quickly. We've actually measured the delay, and it is negligible.
How to connect or transition to regular hose. There are several options, the easiest of which is just to slip the hose into the OE vacuum line as far as you can on the Evo. Yes, that actually works very, very well. The surface are friction between the two materials keeps them together.
1& 2 - We have female fittings that you can use to transition to any hose size you want
3 & 4 - We actually figured out that you can take our very small brass fittings that used to be on the BOV and screw them straight onto any boost connect line and then go on to hose.
For 5 & 6, we've tried to make everything modular and cross compatible so that no matter which version SB, DV or WG you have, you can still use the same lines that you already spent money on. Any of the boost connect line, including the PTFE lines will push onto any barb, or fitting in the product line.
