Post your Synapse DV config and results
#167
Id like to get some opinions on how I ran my vac hose to the dv, decided to just use port b and vent port A to the atmosphere...So far theres no flutter whats so ever...seems to be running fine, boost is alot more smoother.
Should I be fine?
Should I be fine?
#168
^^^That line is very close to the manifold...I wouldn't feel comfortable with it like that. Put a head shield back on the manifold. Also find a vacuum line that is larger then the line coming off the DV and slice the one side of the larger vacuum line. Then slide it over top the line coming off the DV and zip tie it on there. At least that is how I would do it.
#170
I honestly dont' think it matters much for speed density, but I have no real world experience.
In other news, I swap for the PULL orientation earlier, and currently in port B only. Will be testing between the two combination during the week to see what will work best for my upcoming track day at NJMP on Friday. Will be back with updates.!
#171
You're running kinda close to the manifold. The boost connect 90's would work well for that, plus they swivel. I'm more concerned with the material though. That isn't Nylon is it? It may feel hard, but it has a pretty low melting point.
#173
No, the other end that goes to the intake manfold goes straight to the bov.
If you follow the line from the bov in the picture up it goes into the line to the factory line to the intake manifold..All I did there was bypass the outlet closest to the engine to avoid some bends.
#174
Just a note on boost connect. We use them in all of our R&D. They really prove themselves in the data. If you look at the Red line, that is pre-throttle boost. Very clean, and smooth signal representative of steady state flow. The same calibrated sensor was used post throttle at the intake manifold on the blue line and you can see that we are able to pickup the variation of cylinder events with pressure. Boost connect is actually allowing our data acquisition system to pick up these very minute variations.
BTW, this data was not recorded with a Synchronic valve in use.
#175
I have tried out the 3 different possible combination's for the DV. I found that using both ports into a Y works best as far as "flutter" goes. I basically have none this way. Also on a side note.. do not use the quick connect fittings..They do leak. The car was dialed in to 30 lbs with the stock valve and right after switching in the DV valve my boost logs showed a 3 psi increase. So just a word of caution to people upgrading to the Synapse valves..watch your boost as the stock valve might not have seemed like it was leaking when it really was. So you may need to adjust your boost settings.
#177
#178
Over the weekend, I swap the orientation to play with the pull mode in different configurations. My results from PuLL in port B only is similar to push in port B. The driving charateristics are similar. Using PuLL with port A only was horrible, and the valve flutters no matter what rpm you drive it at. The noise sounds cool, but thats about it. I really like the bov in push mode at this point, but I will try out running both ports in Pull mode before making a final decision on what is best for me car.
I hope everyone is having some success configuring the best solution for the own cars!
#179
What we've found is that there will be differences in how each person sets up the valve to their liking, even if they have identical setups.
The chart below shows the valve's operation in raw data form. This is with Port B as the actuation port, and in a system with a control solenoid. You'll find that many of the cars that will be turbocharged in the future will have a solenoid controlled DV. So it is important to have a DV that can keep up with the speed requirements of these systems.
As you can see, at point 1 the solenoid switches to signal the DV open. Within only 10 ms lift is being generated, and full lift within 30 ms. Although there is still that slight pressure rise, it is no where near the same magnitude as the previous example. And, most of it happens without the the valve in full lift. By the time, there is full lift, the pressure spike is attenuated.
I'm pretty confident that our Synchronic valve is one of, if not the fastest actuating valve on the market. I would be interested to see any other manufacturer show their data.
#180
My new Synapse should be here on Friday. I've read through several pages in this thread and it seems like everyone is using a different configuration. Does anybody have a suggested configuration for me based on the mods in my sig or can someone at least give me a good place to start? Thanks!
