Post your Synapse DV config and results
#226
but according to hks website, for the mivec engine only 272 intake is avail, 274 intake cam is only for evo8. I have the 274/278 for evo 8.
http://hksusa.com/products/?id=656
#229
Soa few weird questions.I get to about 10psi then it seems to choke out then all of the sudden if shoots up to 15psi or so. It seems to bounce around alot. I did some WOT pulls before when I was at 30psi but had a serious leak. Im shooting for close to 32psi. Does any know how many turns for the spring to be set? Im set up in push mode with B line only.
#230
#235
im gonna to be ording this DV some time today but not sure which dealer to go through. the guys at ETS will sell it for 175 shipped so im assuming it doesnt come with the EVO kit like it does through no limit. does it matter? do i need the evo kit? and im gonna try it on pull mode B only and see how that works but regardless i have a tune on the 14th at AMS where they will be installing a Grimspeed BC so im sure if there are any problems they will be able to correct it then. once the tune is over with ill post how its set up and working.
i guess im just concernd with the what the hoses connect to....will i be fine without getting the EVO kit?
#236
#237
My only other question or should i say confusion after reading this thread is how the hoses will connect in pull/push mode....by that i dont mean the hoses from ports a and b i mean the hoses that come from the intake and licp....can someone draw me a picture lol (im just confused) but seriously if u could post a diagram showing which hoses goes to what opening on the DV that would be AWESOME....thanks in advance!!!!
#238
Just bought one for 260 with the evo kit....its overnighted for free too so should be here tom. i have the ETS intake.
Hopefully that makes sense and doesn't make you even more confused
#239
It hooks up the same way that your stock DV hooks up. The only thing that might change is whether you run it in push or pull mode. Push mode is basically like a stock DV, where the piston is horizontal and pushes against the air on the UICP and the ports are in a horizontal position pointing towards the radiator. Pull mode is when the piston and ports are in a vertical position and the piston side is connected to the hose going to the intake. Either direction could work for your set-up. It's kind of a trial and error thing.
#240
Sorry didn't realize you had a X. I'm not totally sure on those but my guess would be that the stock BOV does run in push mode since that's how it runs on the VIII and IX. Like I said, it's pretty much a trial and error thing, you just have to try it in push and pull mode and see what works best for your setup, but I think most people are running in push mode.
