Post your Synapse DV config and results
#256
I have tried all configurations and not one alleviates the valve flutter because the spring the Synapse supplies has too much pre load. What I did was take all the allen bolts out and measure the distance the spring is compressed when the valve is pressed together vs just resting on the spring. I then took and educated guess on where to cut the spring just so the enough to keep the spring in compression when i put the valve back together. So i cut the spring and put it back together...work MUCH better. BTW im running with A+B now.
I also heard Synapse is working on a new spring solution? Do we have an ETA on this?
#260
#261
Need some help guys. I'm getting conflicting information. Some people are saying that the instructions on the synapse website are backwards and other are saying its correct..I am looking for some clarification or a second set of eyes. Can someone tell me what port and mode I am using? Just looking for a second set of eyes. I think I am in pull mode B..Thanks in Advance
#262
I own a X so hopefully someone with an 8 or 9 can help u more...........Im gonna take a guess and say its in pull mode (thats what it looks like)
#264
Not sure why u need to be at 10-20 psi in 5th any way but u might just have to work around the issue for the time being till u find a permanent fix.
#265
I get the tiniest amount of flutter in 5th gear when i slowly let off the gas (stock turbo tho) after being in boost, its not all that bad (much better then when i had the stocker). what i do is just let off the gas completely once i have reached the speed i want to be at and either set cruise control or just give it gas again and maintain w/e speed im at my self.
#266
1 Post
I THINK you have it in pull mode but hooked up to port A. Try flipping that setup around. Use one of the small couplings & attach the BOV directly to the UICP and make sure the word Synapse on the BOV is facing up towards the hood. Then run the ETS recirc pipe into the intake. Also hook your vacuum line up to the other port (port B) as I am pretty positive you have it hooked up to port A currently...
BTW nice cam sensor shield...
#267
#268
Hey guys I'm still getting some flutter (usually at or near peak boost) running mine in push mode with port B. Below is a copy of the email I sent to Synapse earlier today. I've tried running the DV with just about every configuration except hooking up A and B and push with port B seems to be working the best, but I'm still getting the flutter as stated above. Just wondering if anyone else might have some thoughts or suggestions.
Hello Chad,
Sorry it's been awhile since I last got back to you on this. I've been working on trying some different things to fix the problem but haven't had much success. I recently did a turbo swap to an Evo 9 turbo and fixed my leaking O2 housing gasket, but after the swap I was still getting the same amount of flutter. I removed the Grimmspeed 3 port a few days ago and put the stock solenoid back in but the fluttering is still there. Then last night I disconnected the boost gauge and the "T" from the line running to the DV but, again, there is no change, the fluttering is still there. One other thing that I noticed on my data logs is that whenever I hear the flutter I also seem get a big drop in AFRs so I'm pretty sure that it's the DV opening and closing and not the wastegate. Let me know if you have any other solutions that I can try. Thanks!
-Ian
Hello Chad,
-Ian
#269
Hello Chad,
-Ian
Hello Chad,
-Ian
Thats strange! Did you ever mess with adjusting nut on top? My only other guess is that there would be a leak somewhere.
