New ATP Ball Bearing Setup
The intercooler plumbing looks like it will be slightly different also. The Garrett is not a reverse rotation turbo, so the compressor outlet comes off the other side.
I think the turbine casting looks larger than it is due to the extra re-routing of exhaust flow to make the normal rotation center housing and compressor work in the space meant for a reverse rotation turbo.
those numbers seem too good to be true on stock everything other than, cams, TBE, 3" FMIC. this could be a beginning of something new. they are one to something. I want 93 pump number.
Are you guys forgetting how these worked out last time they tried this?
http://www.atpturbo.com/mm5/merchant...gory_Code=VEVO
That hard 90 on the turbine inlet seems to kill spool and HP.
They should have just cast a new manifold to use a standard rotation Garrett turbo.
them turbos are looking better then going the FP route.
its nice to see more companies supporting the stock frame turbo trend
id like to see what that 3582 turbo can do on a well prepped car
plus ball bearing over journal bearing all day
