Wierd problem... I need your help!
****UPDATE-VIDEO****
http://www.youtube.com/watch?v=Nn5Cr6tSv0I
Here is a video of the actual problem. Sorry that it's not very clear, but that's the best that I can do at the moment. The video shows a 3rd gear pull and when it hits 6,000 it does a fuel cut and immediately goes back to normal and goes all the way to the limit.
Hello all,
Yesterday I visited the dyno to get a tune for my new setup:
FP Red
PTE 1000cc
Megan o2
ETS 3.5 FMIC with pipes
GSC S2 cams
Well, as soon as my tuner adjusted the timming and AFR's, and started to get on it... We encountered a problem and we can't figure it out... As the car started to go up in RPMs and hit 6,000 it suddenly stalled like if the rev limiter was set at 6,000
. You could see the graph go beautifully all the way up to the 6,000 range and then BAM it didn't wan't to go any further.
I told my tuner that before I installed the new parts I was having the same problem which I thought it was tune related. If I was going 65, go down to 3rd(high RPM) and WOT the car would go with out any problem. However, If I was going 65 in 4th(lower RPM) and WOT the car would obiously lag more, but as it was going up in RPM probably by the time it would hit 6,000 I would encounter the same stall(hick-up) problem but It would go back and keep going till the rev limiter. I'm pretty sure that if we would have keep the WOT at the dyno when we encountered the problem the car would go back at it and hit the rev limiter, just as it does on the street.
My tuner said it could be a bad cam sensor or some other type of sensor in the car. Please if anyone else has encountered the same or a similar problem, please help me out! I will greatly appreciate it. Thanks in advance
Hello all,
FP Red
PTE 1000cc
Megan o2
GSC S2 cams
. You could see the graph go beautifully all the way up to the 6,000 range and then BAM it didn't wan't to go any further.I told my tuner that before I installed the new parts I was having the same problem which I thought it was tune related. If I was going 65, go down to 3rd(high RPM) and WOT the car would go with out any problem. However, If I was going 65 in 4th(lower RPM) and WOT the car would obiously lag more, but as it was going up in RPM probably by the time it would hit 6,000 I would encounter the same stall(hick-up) problem but It would go back and keep going till the rev limiter. I'm pretty sure that if we would have keep the WOT at the dyno when we encountered the problem the car would go back at it and hit the rev limiter, just as it does on the street.
Put the car in 5th at about 40mph and floor it. If your revs climb but your car doesn't accelerate like it should, it's your clutch. You mentioned it doesn't happen in lower gears which would lead me to believe it's your clutch. Higher gears=more load.
Josh
. Now I'm really confused
. However, it was tunes at 27psi before the mods. Yesterday at the dyno it was running at 25psi and in 3rd gear and doing the stall/stutter at about 6,000 RPM. The car also has a greddy electric boost controller.
almost sounds like it is ignition... you may need new plugs, some sort of coil on plug setup or whatever. If the RPMs continue to climb after the hiccup, its not clutch. It would be clutch if the RPMs climbed first, then came back down and the car continued to drive. If i have read this right that is.
During initial tuning of my car on E85 there was so much fuel being dumped until it all got smoothed out that it fouled out the plugs, plugs were brand spankin new when we started tuning. Car was built and tuned at AWD so it didnt even leave the shop to get there for the tune so it was a very short period that they were receiving massive amounts of fuel.
Popped new plugs in and it cleaned it all right up.
The only other thing i can think of is the issues that people had with the FP Reds and comp surge or something like that... i dont remember the thread exactly...
You getting tuned on pump or another fuel?
. Seems to work just fine
