Car wont stay on!! need help!!
Old Dec 15, 2010 | 12:24 PM
lilmarf's Avatar
Im not to sure what is going on with my car. Its on E-85, i have a walboro pump and 1000cc injectors. At times i have to stay turning the key on and off before it actually turns on and when it does i have to give some gas so it doesnt turn off. Can anyone tell me whats wrong plz!!! lool
Old Dec 15, 2010 | 12:38 PM
CtSilver03Evo's Avatar
It is hard to diagnose your problem without info.. Did you recently add mods to your car? You may have a bad boost leak, a faulty MAF, etc.. My point is this: There are several things that it could be. Please provide more info. Thanks.
Old Dec 15, 2010 | 01:04 PM
lilmarf's Avatar
I have an 02 dump, espelir exhaust, keflord 272s, springs and retainers, ported exhaust manifold,mbc, 3in intercooler, injen piping, 1000cc injectors, and a walboro fuel pump.
Old Dec 15, 2010 | 09:28 PM
nnb239's Avatar
Your cams, Idling problem. Is your car tuned?
Old Dec 16, 2010 | 08:47 AM
lilmarf's Avatar
yup the car is tuned on e-85.
Old Dec 16, 2010 | 03:41 PM
NitrousOxide's Avatar
Checkout if ur cam sensors are ok or not, also checkout the coil-on plugs if they're not leaking..
Had the same issue once!
good luck!
Old Dec 16, 2010 | 03:50 PM
05VIII's Avatar
seems to be low fuel pressure. do you have a gauge for fuel pressure? check your vac line to the FPR.
there are hundreds of reasons why it wont run. really hard to diagnose with out more information.
were any mods done recently?
