4G64 build
Old Dec 29, 2010 | 05:11 PM
jrlewis0550's Avatar
Originally Posted by RockmanX
a new hta green is not even being close to pushed at 400whp now once you get to 500whp on e85 you about there highest i have seen was 517whp 500tq out the hta green on e85 on stock motor. yes the guy blew his motor he knew the risk on stocker motor but if you get it built you will be fine there
Ok so i live in NH, and there is no E85 so thats not an option. I have meth in my supra and it makes around 600 on a 6765 so i dont want anything crazy. I just want a pump winter car. If the HTA green can make 400 on pump with a conservative tune then its probably my top choice. What size injectors should i be getting?
Old Dec 29, 2010 | 06:08 PM
cij911's Avatar
I am making more than 450 whp with the HTA Green and a 100% stock 2.0 motor. I am running 91 + 50% h2o & 50% Meth ~ 95 oct. or so. My guess with a 2.4, with cams, and 93 octane you could easily be 450 - 475 whp.
The HTA Green ROCKS !
All this said, with a 2.4L, you probably want to go a tad bigger like a Red or even a Black because of the increased displacement.
Old Dec 29, 2010 | 06:29 PM
JohnBradley's Avatar
Average price on all the parts and machining is generally going to be right around 2700 retail or so for all the parts and block. That is everything and using the normal parts suspects as a "kit". Machining varies from shop to shop but make sure they have a torque plate to bore and hone or there is no reason to use them.
Old Dec 30, 2010 | 04:56 AM
Yeah im not sure who im going to use as a machine shop but i will make sure they have the plate. I want to go like .20 over to make sure everything is good. If i run 4g63 internals what kind of compression would i be looking at.
benIX
Nov 26, 2016 07:58 AM
jbeaton9292
Nov 30, 2014 01:05 PM
babaz7
22
Mar 26, 2013 11:53 PM
dsevo
218
Feb 12, 2010 10:25 AM
Evo8Emperor
21
Nov 24, 2009 03:42 AM
