New BW EFR Turbo Thread
.I like that collector. Seems like it will save a bunch of effort for building a manifold.
All the EFR turbos are very long. While the dimensional specs on the 7163 have yet to be released, the TS T4 IWG version will likely be 10" end-to-end just like the 6758. I'm pretty sure that wont fit in a bottom mount configuration, even with the turbo tilted a bit to try to make room for the DP. The TS T4 EWG will probably be 8.5". Since FR has been able to do a bottom mount with the 7670 and 8374 EWG, should be even easier to do this one in bottom mount.
there is a SS v-band EWG version. no T4 TS as you said. i forgot.
text me some time.
do you mean jeff perrin's results on an early version with a single scroll 0.64a/r? boost-for-boost, it came in about 20 whp below a 7670 in the 450 whp. the best believable dj result i've seen on a 7670 with full supporting mods on a built motor is 575 whp. putting those two tidbits together gives me my 530 whp guess. have you seen any other results?
Info:
http://forums.nasioc.com/forums/show....php?t=2394879
As far as beating on the turbo, I think I have that one on lock with my 6258 equipped Yamaha. Before you discount it because its the 6258, let me explain why.
A Yamaha Raptor 700R runs 7psi oil pressure stock. We mod the pump and get 10-11psi at full pressure and basically 1 at idle. It is a 2 quart system with no oil cooler that also lubes/cools the clutch and transmission
I do watercool the center but it has 3 quarts of water between the turbo and the motor. Normal operating temp is 200-210 and the fan kicks on at 225*F.
My quad makes 103whp and has just over 110 hours on the turbo. For a car to match the amount of full throttle and full boost that my bike sees it would need a similar amount of time on a road course. I change the oil every other ride and I normally get 24-25hours per 3 day weekend of riding (I love to ride and spend more time on the quad than in camp). I run E98 which of course leads to diluted oil over time which is why I change it frequently.
The turbo single cylinder design inherently runs in boost at cruise. I am only running 12psi or so but it cruises at 2-3 and it does this non stop. The only time its not in boost is either decel or idle.
If the smallest bearing housing available has proven reliable under these conditions I really have no concerns about a larger center section with "normal" driving and cooling/lubrication systems.
