New BW EFR Turbo Thread
Old Jan 14, 2016 | 06:06 AM
  #3766
awhit17's Avatar
Originally Posted by Evolution X MR
Has anyone used the Driven Fav EFR Turbo Kits? I really want to go this route with my turbo upgrade. They sell a lot of great products I have purchased from them
I have a friend who purchased their kit with a 9174. The downpipe was making contact with the transfer case when installed.
Old Jan 14, 2016 | 10:08 AM
  #3767
94AWDcoupe's Avatar
picked up this indy car 6758 this week. found the tiniest return line I have ever seen. hard to believe a cart team would be in error here?? the feed restrictor on the inlet is also tiny. maybe .035. so maybe there is not much return volume?
Old Jan 14, 2016 | 10:12 AM
  #3768
honda-guy's Avatar
what's the ring blow by on those cart engines though. i would think they have pretty tight tolerance. do they use crankcase pump also?
Old Jan 14, 2016 | 10:14 AM
  #3769
LetsGetThisDone's Avatar
The only way I see that working is if they use a scavenge pump for the turbos.
Old Jan 14, 2016 | 10:17 AM
  #3770
kikiturbo's Avatar
BW states that 8AN outlet fitting with a 1/2 inch line is "nice" for oil outlet...
as for indy turbo... those engines run some really thin oils IIRC..
Old Jan 15, 2016 | 05:15 AM
  #3771
hispanicpanic's Avatar
Whatever an indy car does, don't replicate it. Their a dry sump system, run oils that us mere mortals cannot obtain, and damn near press fit their pistons into their bores.
Old Jan 15, 2016 | 08:13 AM
  #3772
Nothing like running 8" of vacuum in the crank case to promote turbo draining lol.
Old Jan 15, 2016 | 12:57 PM
  #3773
BiFfMaN's Avatar
Does that mean I should not be wearing my Flame retardant suit every time I drive to pick up milk?
Old Jan 15, 2016 | 08:47 PM
  #3774
wings1833's Avatar
Originally Posted by x622
EFR 9174 w/ 1.05 AR housing and a quick spool valve.
this is an aftermarket quick spool valve, right? Not one from BW, correct?
Old Jan 16, 2016 | 11:11 AM
  #3775
x622's Avatar
Correct, a sound performance.
Old Jan 17, 2016 | 12:48 PM
  #3776
RWD4G63's Avatar
Dry sump solves all oiling issues.
At PRI they recommended at LEAST -10 for all of their turbos, and not to use the threaded adapters on the EFR's, as it makes the return too small.
Southeast Power Systems makes these big bore -10 adapters specifically for the BW range. You can see the ID difference with a threaded adapter.
HAHA, I actually laughed out loud. Good one.
Old Jan 17, 2016 | 01:26 PM
  #3777
kikiturbo's Avatar
I agree with you, threaded adapter is no good.. also there are only like 3 threads in the 7163 oil outlet..
but you can get that 10AN adapter from Vibrant..
I think it is this one but should check the bolt holes..
http://vibrantperformance.com/catalo...oducts_id=1276
Old Jan 23, 2016 | 04:42 PM
  #3778
RS200's Avatar
I made a thread about this, but is it possible to use an aftermarket boost controller (non-ECU) with the EFR solenoid? (In my case, Blitz SBC i-D)
Old Jan 24, 2016 | 05:16 AM
  #3779
kikiturbo's Avatar
it should work, yes.
Old Jan 26, 2016 | 06:31 AM
  #3780
Balrok's Avatar
In for 8/9 Twinscroll dyno's.
