Car stalls, why??? (video)
pretty much you have to adjust the idle set screw so whatever amount of air is passing in will play friendly with the idle air controller settings on the rom..
ive been there done that.. im offering help because ive fixed this myself on my personal evo.. and yes its very annoying.
for the books the proper term for the sensor is a idle speed control servo.
you have to lock the sas actuator to hold the idle air controller in a frozen position while adjusted the idle screw so it doesnt alter its steps.
atleast the cars not stalling now though like it was before.. not only is that dangerous in traffic, but super annoying and hard on the starter.
in neutral if you rev the car to like 6000rpm and just let go of the gas does it dip below 1k etc?
also what timing in the idle area? and what rpm target in the ecu settings?
My car used to do this bad when I had an intake on it. I went back to the stock airbox and its been a lot better ever since. It will still do it if the engine is heavily loaded and I take the load off (ie pushing in the clutch), but its not nearly as bad as it was. I've just learned to live with it.. Good Luck.
https://www.evolutionm.net/forums/ec...hout-pics.html
Fireescape
Jul 4, 2016 11:18 PM
ptm5070
31
Jun 24, 2014 08:44 AM
MarkChamorro
Jul 14, 2012 10:20 PM
