Anyone know the difference in the Exedy triples? SR and HR
Old Mar 8, 2011 | 11:14 PM
My03evo's Avatar
Arrow Anyone know the difference in the Exedy triples? SR and HR
Anybody know the difference from the 2 triples (cerametallic) that Exedy makes?
They got MMO23SR and MMO23HR
The HR is rated for roughly 120-150 lbs ft more holding capacity than the SR.
I need to decide in the morning which to get and want to know the differences, Either will hold my power but doesnt hurt to have more growing room if the only difference is a small increase in pedal effort.
Anyone know? one has the SD pressure plate and the better has the HD pressure plate maybe? The triple I just pulled out has the same pressure plate as the HD twin.
Thanks
Old Mar 9, 2011 | 05:40 AM
boonkae's Avatar
Get the MMO23HR ..
I'm using it for 2 month now ...
Do remember to properly run it in ...
If compare to my old hks twin plate ...
Its only a little bit heavier & i do daily drive it ...
So far so good ...
Old Mar 9, 2011 | 05:48 AM
dieselmd's Avatar
You are correct; the SR has the SD pressure plate and the HR has the HD.
Old Mar 9, 2011 | 06:14 AM
itzwolf's Avatar
I would always opt for the HD pressure plate no matter what. I see no reason for the SD anymore and wouldn't be surprised if its discontinued one day.
Old Mar 10, 2011 | 09:03 AM
My03evo's Avatar
I read somewhere someone had an SD twin and wanted to upgrade to the hd twin so they emailed exedy to see if they would swap the the pressure plates and they said no they dont make the sd plates anymore and don't want it aha but idk
Either way I ordered the hr, and I found out its the same one that I just took out so I know it wont be annoying, except unless I get this disengagement problem AGAIN just like half the people on here with multiplate exedy's
Old Mar 10, 2011 | 10:08 AM
High_PSI's Avatar
Always make sure to get the HD.
Old Mar 10, 2011 | 11:05 PM
My03evo's Avatar
Why do you say that?
Old Mar 11, 2011 | 07:14 AM
boonkae's Avatar
Here is mine before being installed ...
Old worn HKS twin plate ...
Old Mar 11, 2011 | 07:33 AM
itzwolf's Avatar
The idler plates can warp easily due to a lot of heat, especially in stop and go traffic. I know fomr experience I just had to rebuild a transmission over it because when the clutch was rebuilt one of the plates wasn't properly checked by the shop doing the work. Live and learn.
It's the nature of the beast... there is always a compromise somewhere.
Old Mar 13, 2011 | 09:43 PM
My03evo's Avatar
I do agree totally, although some people have had issue with the clutch out of the box, and some have been fine for 50k miles, granted they might not be in traffic everyday but neither am I and I only put 4k miles on it and I drive 90 miles out of 100 miles daily on the highway and I shift so smooth the clutch rarely does work except for take off. I drive 18 wheeler trucks everyday and if you cant shift it at the right time then it wont shift period.
I'm going to check my plates with a straight edge tomorrow to see if I can see any warpage, I had adjusted the clutch so much that even if it was warped it still should have been plenty enough to disengage it enough to seperate any dragging plates.
Exedy says to stagger the gaps in the friction discs so they are not lined up all with each other but looks like they are in the second pic above ^^^^ Wondering why they marked it against their own advice? I just got my new triple with the hd pp and my gaps were staggered.
Pure Playaer
32
May 5, 2013 09:23 PM
car_nut15
Apr 15, 2013 09:32 PM
daxilej
10
Aug 21, 2008 03:17 AM
daxilej
Aug 17, 2008 03:06 PM
jbergmeier
Feb 18, 2008 06:12 PM
