it finally happened
Old Mar 28, 2011 | 10:30 PM
Evoleader88's Avatar
it finally happened
so my motor finally took a dump on me and poke a hole thru it, its time for new bottom end (shortblock), but i have 3K in budget, my goal is building a short block that can handle at least 500whp no problem, im only going for 550wheel, jus doing 2.0 built.... so chime in give me some advise on pistons, rods and other parts
Old Mar 28, 2011 | 10:32 PM
kanyonkid's Avatar
do it once...
https://secure.buschurracing.com/cat...f5a72bb16d7e66
Old Mar 28, 2011 | 10:38 PM
my block is toast, i dont have anything to exchange the core, i was thinking buy a used core from forum or local and built it
Old Mar 28, 2011 | 11:39 PM
S13 Curtis's Avatar
Build a 2.1.
Old Mar 28, 2011 | 11:49 PM
LGshow19's Avatar
2.4 or 2.1 since you dont have a block. 2.4 with a fp green/red/black will get you what you want.
Old Mar 29, 2011 | 04:59 AM
SmurfZilla's Avatar
+1,
You budget will go up from 3k. Even if you do it yourself. Things add up quickly.
Old Mar 29, 2011 | 05:15 AM
sr20det91's Avatar
3k budget is gonna be next to impossible. Is your head still in good shape.
Reason I say is because the same thing just happened to me. I got a really good deal on a brand new factory short block from King Mitsu. in gaithersburg MD for around $2500 and that was the best deal I could find(no core required). If you need head work add a minimum of a grand to that. Not to mention gaskets,oil pump water pump, timing components,fluids etc...it adds up super fast.
Luckily Im' doing mine myself and all said and done I'm at close to 5k, granted my intake valves got smashed so Im having Jackson Auto Machine build a stage 2 head. That adds about $1300.00 give or take.
So if depending on weather or not you do the work yourself, 3k is barely going to get you started.
Old Mar 29, 2011 | 05:30 AM
Jrah2987's Avatar
Veteran: Air Force
Yeah, you're going to be spending at least a grand on various oem parts that should be replaced like the gaskets, belts, pumps, etc. It might be best to just start stocking up on parts before you get in over your head.
Good luck.
Old Mar 29, 2011 | 05:39 AM
tsidrift1's Avatar
This is why I wont push my stock block. The damn core charges are waaaay to high!
If I were you, just pick up a used 8 block, buy the internals, and build it yourself. Easily be under the 3k budget.
Old Mar 29, 2011 | 05:46 AM
Jrah2987's Avatar
Veteran: Air Force
You can get a 4G64 block w/ crank for ~$500 from AWD Motorsports.
Old Mar 29, 2011 | 05:51 AM
RJSP's Avatar
Sorry to hear about your engine... What let go? Rod? Rod bolts?
Good luck on your rebuild,
Ricardo
Old Mar 29, 2011 | 06:58 AM
psphinx81's Avatar
my bottom end cost me $4800 alone lol.
Old Mar 29, 2011 | 07:15 AM
TommiM's Avatar
Ricardo
Sounds like the block wasnt strong enough to keep the pistons inside.
Old Mar 29, 2011 | 07:18 AM
stck_trbo_mnstr's Avatar
how much power where u making on the stock motor? and what happened
Old Mar 29, 2011 | 07:38 AM
xmaciek82x's Avatar
Curious to what happened as well. You were running a stock turbo, don't see why your engine would blow....
