oil pressure gauge w sandwich plate?
getting ready to do my gauges and wondering if the oil filter sandwich plate is a good idea to install my sending unit. looking at prosports or mishimotos. any experience or suggestions welcome.
the factory oil filter housing assembly has 2x grub screws in it.
just remove them and then use one of those holes for oil pressure and/or temp.
you will need to heat them with a flame torch to break the loctite on them.
thats where i am running my oil temp
not sure about the evo 9, but a sandwich plate on mine would put the filter too low to the ground...
you can see my FP oil line adapter that i've taped over.
you can just see the end of the bosch fluid temp sensor on the left of it
twnty100drummer
Apr 26, 2012 03:45 PM
Chabada15
25
Jun 3, 2009 05:36 AM
