Kaaz & Redline Light Weight S.Proof T.Case Mixture?
Old May 4, 2011 | 08:51 AM
jameswwt's Avatar
Hi,
can i mix Kaaz lsd gearbox oil with a liter of Redline light weight shock proof?
My intention is to gave a better lubricant on high temperature thereby prolong the the gearbox life span...
What do you think?
Old May 4, 2011 | 01:04 PM
RSMike's Avatar
where are you exactly using kaaz oil?
the gearbox, transfer or rear diff?
it was my understanding that Kaaz oil is used for clutch type diffs. And i would assume the only clutch type diff you have is the rear diff, unless you have a Cusco front (which is in the transfer).
Cheers, Mike
Old May 4, 2011 | 04:54 PM
jameswwt's Avatar
Cheers, Mike
What!!! OMG!!!
Ive been using Kaaz oil for my gearbox and transfer case all the while...
On the Ayc im using Mit Diaqueen AYC oil.
Btw, beside ayc is there any other oil i need to change on the rear? As ive noticed there is another drain plug beside ayc.
Old May 4, 2011 | 05:50 PM
RSMike's Avatar
i'm sure it's ok.
it's mineral oil though isn't it?
i wouldn't mix mineral and synthetic (redline) oils.
i run a mix of 75W90 and 75W140 oils, but they are both Motul gear oil and states it's ok to mix.
I've run a mix of Lightweight shockproof and Heavyweight shockproof before and there was no problems.
Check these oil recommendations out
http://teamrip.com/manual_transmissi...tion_info.html
http://teamrip.com/transfer_case_hyp...tion_info.html
http://teamrip.com/rear_axle_hypoid_...tion_info.html
Old May 4, 2011 | 06:06 PM
jameswwt's Avatar
i'm sure it's ok.
Thanks Mike
Btw, is there other oil i need to change at the rear beside the ayc?
Old May 4, 2011 | 07:03 PM
RSMike's Avatar
i dont know much about the AYC sorry.
read up on the service manuals and go from there
Old May 5, 2011 | 03:05 AM
jameswwt's Avatar
Thanks
Nelo
Dec 23, 2016 07:35 PM
nuggetinu1
Feb 15, 2016 03:16 PM
Iceywater
14
Aug 12, 2014 10:09 PM
jameswwt
Jan 10, 2011 08:38 PM
evo 8 ya
Evo 'For Sale' Services
41
Dec 11, 2010 06:45 AM
