How to Improve my GT3076R Response?
Old Jun 4, 2011 | 09:11 AM
SyZyGy1394's Avatar
Could be your boost controller and/or tune. How lean are your afr's during spool? What fuel?
Old Jun 4, 2011 | 09:18 AM
supersal's Avatar
hi
Sounds like you have a GT35R
GT30R gets full boost at around 4300...
Maybe you have a exhaust leak, post pick of your manifold wastegate setup...
Old Jun 4, 2011 | 09:29 AM
mt057's Avatar
Originally Posted by jameswwt
Oic...Thanks for sharing or maybe is the profec b II bc setting...
Anyway, will send for retune next week....
Dam! how jealous im on yr result Boonkae!
Mind to share which tuner you sent you car to?
What is your setting on the profec?
What mods?
BoostINurI's Avatar
Get a MBC and trash that greddy crap ebc....$.02
Old Jun 4, 2011 | 09:48 AM
jonmorera's Avatar
From: Costa Rica with business addres in Miami FL 33166
I have the same problem, here is my log and rom tuned to 1.5 bar, maybe someone can help me to reduce the lag. thanks guys.
My mods are:
kelfords 272 hks valve springs
walbro fuel pump
720cc Denso injectors
big intercooler.
2.5" all turbo pipes
3" complete exhaust
stock manifold
0.82 AR GT3076R
injen turbo intake
ARP head studs
Evo 9 pistons and rods
This is my engine:
My Log: https://www.evolutionm.net/forums/at...se-logevo6.zip
File Type: bin
Old Jun 4, 2011 | 10:00 AM
jameswwt's Avatar
Hi, my afr's during spool should be 11~12 and we are using RON 97 but i duno what's the octane value here in Malaysia.
Old Jun 4, 2011 | 10:02 AM
jameswwt's Avatar
Originally Posted by supersal
hi
Hi Supersal my friend,
how to check the exhaust leak? u r refering to the exhaust manifold part?
Will post the picture tomorrow.
Old Jun 4, 2011 | 10:08 AM
jonmorera's Avatar
Maybe someone can upload a bin and log that shows a perfect mixture and timing for a good spool and power, just to consider how to make a good tuning.
Old Jun 4, 2011 | 10:09 AM
jameswwt's Avatar
What mods?
Low Boost :
Set = 35%
Gain = 12%
Set Gain = 1.15
Warning = 1.63
Limiter = 7%
High Boost :
Set = 45%
Gain = 15%
Set Gain = 1.20
Warning = 1.75
Limiter = 10%
I hope i set it right...
Old Jun 4, 2011 | 10:23 AM
boonkae's Avatar
My mods are:
walbro fuel pump
big intercooler.
3" complete exhaust
stock manifold
0.82 AR GT3076R
injen turbo intake
ARP head studs
This is my engine:
Are you using original exhaust manifold with ATP's adapter for gt3076r ?
I heard its very restrictive ...
Old Jun 4, 2011 | 11:09 AM
dastallion951's Avatar
well from what I remember james is the set is your target boost, and your gain is how quick you hit that target, what you can do to experiment, is how you have it set now, write down all your specs, then try keepin your set where its at and experiment with the gain increasing it in 5 to 10 increments, see if that helps your spool. maybe increase your set gain up .5 to .10 see if that also helps.
Old Jun 4, 2011 | 11:15 AM
jameswwt's Avatar
Thanks Dastallion...
Old Jun 4, 2011 | 11:39 AM
mt057's Avatar
Low Boost :
Set = 35%
Gain = 12%
Set Gain = 1.15
Warning = 1.63
Limiter = 7%
High Boost :
Set = 45%
Gain = 15%
Set Gain = 1.20
Warning = 1.75
Limiter = 10%
It looks good to me. The only thing that I like to do is have the ebc take over right at wastegate pressure. You might try playing with the set gain.
Old Jun 4, 2011 | 11:51 AM
suby2evo's Avatar
swap it out for an HTA green
Old Jun 4, 2011 | 01:51 PM
jonmorera's Avatar
Yes it's correct!!! Maybe a good tubular manifold, with tubular manifold the turbo response will be best, true??
