IV powered OZ.
Old Jul 1, 2011 | 03:09 PM
*02Lancer*'s Avatar
IV powered OZ.
Hello all, I’m in the middle of swapping an Evo IV engine into a 02 lancer oz and I am looking for help. I’m having problems finding information out on the Evo IV. The main concern I am having is the harness, and sensors. I have the complete harness and ecu out of the IV but I’m going to be swapping it to evo VIII harness and ecu. What I can’t seem to find are sensor values, For the IV so I can compare them to the VIII so I know what sensor's need to be replaced. The car is going to stay FWD only. And I have found mixed information on the transmission and transfer case. Once source stated that they are the same transmission while transfer cases are different. And another source states that both transmission and transfer case are different. What I’m doing to keep the vehicle FWD is I have pulled the IV T-case apart and was about to send it to the machine shop to have a spool put in place of the spider gears and Once that was done I was going to remove the pinion gear and build a block off plate to retain the fluid. But what I don’t know is if Evo VIII stock axles still work, If not custom axles can be made. Any and all information on the Evo IV would be greatly appreciated. Thanks all
