Eagle rods, fail!!!!!
I don't see that crack allowing enough coolant in at 5K to cause the cylinder to go solid. The cylinder would have to ingest enough water in two stokes (down and up) to fill the combustion chamber. The water coming in is under pressure, the air is under pressure and part of the time the piston is blocking the flow. It seems to me, until the engine was stopped, the best you would have is water injection.
The smallest amount theoretically able to hydro-lock an engine would be just slightly greater than the volume of a single cylinder when the piston is at top dead center.
Which if my math is right -- is only about 50ml.
43cc + 6cc dish = 49 + ....
From the fuzzy picture I can't see much, but if that is a crack then sure, this is a bad hole. However, at 5000 rpm (per the OP) for the combustion chamber to fill the crack would have to be flowing at at least 60 gallons per minute and part of the time the piston would be blocking this flow and sending it to the pan. This if all the water was being ejected through the exhaust valves. Some water would stay but still this requires a lot of flow.
well it couldve been as simple as op got a friday or monday built set of rods. Its a crap shoot, and not just limited to eagle rods. Looks how some people with ixs had an issues with cams snapping the mivec cam gear. Parts break, it happens when extreme temps and pressures get put on metal. Can happen to anyone of us on anyday. Now to you experienced engine builders, with the rods like these known to break, would it be worth if it op did buy another set of eagle rods, to have them cryo treated to have the metal strengthened on a molecular level. Im just thinking that could help a future builder, granted it is some money to have it done, but to take a steel rod and do that wouldnt you be increasing longevity due to the fact that the rods can take a beating even more.
moyassine
Jan 19, 2016 01:13 PM
