low oil light
Old Jul 30, 2011 | 02:13 PM
justastockevo's Avatar
low oil light
i have a low oil light coming on all of a sudden today.
if i hit the throttle it disappears however.
my defi oil pressure gauge shows 20 psi or so at idle, just as it always did.
is it my oem oil pressure sensor? or should i prepare myself for something much much worse?
Old Jul 30, 2011 | 02:33 PM
meckert's Avatar
10 million threads on this---replace the sender and at least attempt to look thru the threads as in search... pls.
Old Jul 30, 2011 | 02:38 PM
i did, they range from spun bearing to defective sensor. what are my chances if other gauge is showing the proper pressure?
Old Jul 30, 2011 | 02:45 PM
meckert's Avatar
You gauge sounds rt--maybe high. The senosrs are going out on everyone. Its cheap replace it and see.
Old Jul 30, 2011 | 02:47 PM
nytalonTSi's Avatar
If the reading is where it usually is, which 20psi at idle is normal then the sensor has to be defective. When they go bad they usually start acting up.
Old Jul 30, 2011 | 03:19 PM
actually, i totally forgot to mention, my car had a history of oil pressure gauge problems.. first, i had vei gauges, oil pressure among them.. went showing 2 psi at idle... then i've replaced sender... half a year, same deal... swapped vei in favor of defi.... guess what, low oil pressure again, we have cleaned the contacts with silicon spray, everything's working again... now this.
sorry for making this thread at all, i'm simply pissed off at that, folks..... why it is just not working for me..
Old Jul 30, 2011 | 07:34 PM
barneyb's Avatar
Do you drive an 8 or a 9? The 9's are notorious for bad OEM sensors.
Old Jul 31, 2011 | 01:38 AM
i've got a 9.
i've googled up pictures of both 8s and 9s senders, they're visually identical, except 8s has its output contact straight, and 9s is angled. the location on 9s might be a bit of a problem since the oil might be dirtier near the filter... ok, i'll replace it and report to this thread.
Old Aug 5, 2011 | 06:13 AM
in a day oil light stayed turned on almost always, no matter if it's 15 psi or 100 psi on my defi gauge.
oem oil pressure sensor was on two weeks backorder so i tried cleaning a sender's contact with wd40, no effect. ordered a replacement sender Tama PS131 which has the same characteristics as an original mitsu one, had a 3 days delivery time on that. ordered an oem as well just in case tama is no good.
right after sender replacement to tama's everything is back to normal. thanks everyone and sorry for another useless thread.
